Install iTunes on your computer. It is available from apple for a free download by clicking here.
Then follow the steps outlined in this tutorial to guide you in moving the music library from WMP to iTunes.
If you already have a music library in iTunes, simply plug your ipod in to your computer and synch the ipod with your library. It will do this automatically in most cases.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
To reset iPod mini:
1. Toggle the Hold switch on and off (set it to Hold, then turn it off again).
2. Press and hold the Select and Menu buttons for at least 6 seconds, until the Apple logo appears.
Download Apple iPod Mini Manual
jplasky,
GO to the following link and follow these instruction's How to reset iPod . Before that read both articles. This one first Restoring iPod to factory settings then the other before choosing your initial pathway. Fare. Well.
You need to sign on to Apple iTunes through a PC / MAC or tablet, then request to "Change Password"
If you don't know your old password, iTunes will send you an email to ensure that the correct user is attempting the change.
Forgot iPod PASSWORD How to FIX IT without restore . I have hooked you up to the entire process so you can follow along. There are other jump off points from here. I think it is best not only to provide a direct answer from now on. Moreover, a way for you to dissect then learn the process as we help it other to pay it forward. You will be good. Go for it.
There I think is a was to hold two buttons at once..it worked on my ipod 2nd generation...I think it is the menu button and center button..an apple logo should appear, that is when it is reset...
You can restore the iPad by plugging it into a computer with iTunes installed, and clicking restore. This should remove the password. BEWARE you may lose data by doing this, ensure everything you need is backed up.
The iPod model A1236 is the iPod 3rd generation Nano. This specific model Nano is characterized by its small, square shape; the models before and the models after are long and narrow. If you find that some files will not open on the iPod or you continuously receive errors, you have two different options of trying to correct this issue. You can reset, or restart, the iPod, or you can reset the iPod to its factory default settings. You will lose all of your information if you choose to restore the device to its factory settings. Open iTunes on your computer and connect your iPod to the computer using the iPod USB cable. Connect the small side of the cable to an open USB port on your computer, and connect the large side to the bottom of your iPod. Select the Nano device on the left side of the window. Click the "Restore" button within the devices "Summary" tab and confirm that you want to restore the iPod to its factory settings. The restoration process begins after you confirm. Wait for the progress bar to complete. The restore will be finished when you see the "iTunes Setup Assistant" appear on your computer screen. Reset with the Click Wheel Slide the "Hold" switch to the on position, and then to the off position. Press and hold the center button and the "Menu" button at the same time. Hold the buttons for six to eight seconds until the Apple logo appears. The iPod will reset after the logo appears.
No electrical item can be washed in a washing machine!! The cost of repairing this would be as much as a new one!Sorry Brian! Sling it in the bin, you haven't got a chance in hell of getting this working.
