20 Most Recent
BenQ Joybee 210 MP3 Player Questions & Answers
HELLO, I AM TRYING TO
Have you checked the file specifications' that the player can play? Some players can play jpgs of a specific resolution or color depth.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FiXya link: http://www.fixya.com/users/technical114
Joybee 210 mp3 player
1st - make sure the hold/lock is not engaged
2nd - you might need a patch to get that to work with XP:
http://www.benq.us/support/downloads/downloads.cfm?product=712&page=downloads&dtype=D
will have all the software you need
Frozen?
Make sure hold/lock is disengaged
Then reset - check you manual, because BenQ no longer carries the manual
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
