20 Most Recent
Seiko SHC041 Watch Questions & Answers
Where can i find watch dial for shc041
Firstly, what is a shc041? The cleats are called dial feet. They orient the dial to the movement so 12 is always at the top. When they break the dial spins around. Three solutions. Anew dial from the manufacture. A used dial from another watch, maybe from a popular auction site, or "dial dots". Small adhesive dots used to adhere dials with broken dial feet to movements. Sometimes successful, sometimes not. A forthis to send the dial to a dial refinishing company and have new feet soldered on.
How can I turn off the alarm on my Seiko quartz alarm
TO CANCEL THE ALARM TIME YOU HAVE SET ;
1.Pull out the crown to the first click, and press and hold button “B” until the alarm hands stop to indicate the current time.
2. Push the crown back in to the normal position.
Reset time on a seiko solar watch
you should be able to set it with the stem if your having trouble it may have to go into seiko the solar watches can be very complicated
How do I reset the Seiko ch-899
You can follow these steps to reset your watch manually:
- Press and hold "SET" button for 2 seconds until the hour digit.
- Press "ADJUST" button to change the value of the hour digit.
- Press the "SET" button once, the minute digits will flash.
- Press the "SET" button once, the second digits will flash.
- Press the "SET" button, "12H" or "24H" will flash.
