20 Most Recent
Ematic ESB212 Wireless SoundBar with BluetoothBlack Questions & Answers
USING SOUND BAR FOR BLOWN SPEAKER ON TV
If you use Blue Tooth, wires are not needed.
Press the manual Mode button to find blue tooth mode. Green light will display. Blue Tooth is a general signal sent out. There is no specific setting for TV.
If your TV is sending out a Blue Tooth signal, it should find the speaker automatically.
http://www.ematic.us/sites/default/files/ESB212_Manual_01_0.pdf
Check your TV's Blue Tooth settings and have it scan. Default password/code for the sound bar is 0000.
Also check your remote batteries. Sometimes they are installed backwards by the factory so they won't go dead.
Format error even thought I am using amv video ematic mp3 player em208vidbu
please attempt to test out multiple mp3 files on your mp3 player to determine whether the issue is with the files or the device. If possible, please also test the mp3 file on your computer to rule them out as the issue. You can then restart your device and attempt to play the mp3 again.
Thank you.
