20 Most Recent
Pioneer DEH-P4700MP CD/MP3/WMA/WAV Receiver Questions & Answers
Pioneer DEH-P4700MP
Disconnect the battery cable from the vehicle for at least 5 minutes. if this does not fix your problem, the radio will need to be replaced or serviced. Good Luck
11/27/2010 2:00:04 AM •
Pioneer...
Answered
on Nov 27, 2010
I have an pioneer deh p4700mp and when i try to
Take the faceplate off and check the metal contacts on the deck and on the rear of the faceplate... Make sure they are clean and all intact..
You can use a soft pencil eraser to clean the metal contacts.. see if this improves things.
11/27/2009 3:49:37 PM •
Pioneer...
Answered
on Nov 27, 2009
Set the clock
From what I can remember you need to shut off the stereo by holding down the source button and then hold down the function button until the settings come up. The keep hitting function until the time setting appears
2/25/2009 2:36:36 PM •
Pioneer...
Answered
on Feb 25, 2009
How to change time on Pioneer Carrozzeria avic hrv22 it has only Japanese, that's what my car's audio/GPS system and, please, help me out with changing language to English and finding maps?Thanks!!
Changing the language and updating maps on a Pioneer Carrozzeria AVIC HRV22, which typically comes with Japanese language settings, can be a bit tricky, but it's possible. Here's a general guide:
- Locate the Settings: First, try to navigate through the menu to find the settings option. It might be represented by a gear icon or a wrench icon.
- Use a Translation App or Guide: If you can't understand the Japanese menu, use a translation app on your smartphone to translate the menu options. Alternatively, you can search online for a guide or manual in English for your specific model.
- Change the Language: Once you've located the settings menu, look for an option related to language settings (???? in Japanese). Select it and then choose English (or ?? in Japanese). Confirm your selection.
- Update Maps: Updating the maps might require accessing a specific section of the menu, typically labeled something like "Map Update" (????). Once you're in that section, follow the prompts to update the maps. This might involve connecting the device to a computer and downloading the updated maps from the manufacturer's website.
- Follow On-Screen Instructions: Throughout the process, pay attention to any on-screen instructions or prompts, even if they're in Japanese. Sometimes, the navigation buttons or layout might remain consistent regardless of the language.
- Reset if Necessary: If you accidentally get stuck or lost in the menus, there might be a reset button somewhere on the device. Pressing this button will restore the device to its factory settings, allowing you to start over.
If you find it challenging to navigate the menu or if the options are not readily understandable, you might want to seek assistance from someone who understands Japanese or consult a professional who specializes in car audio/GPS systems. They can guide you through the process more efficiently.
