20 Most Recent TDK Microcassette 60 min Micro Cassette Questions & Answers
Erasing the TDK microcassettes
use a bulk magnetic tape eraser from radio shack. the eraser head in your machine is mal-adjusted and, would be too difficult to fix
7/1/2009 1:35:05 AM • TDK... • Answered on Jul 01, 2009
Sonilex mp3 player
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjb3NfpyqODAxV8pIkEHdrGARoQFnoECCIQAQ&url=https%3A%2F%2Fwww.flipkart.com%2Fsonilex-sl-mp16-8-gb-mp3-player%2Fp%2Fitmeamgzmehkuxfy&usg=AOvVaw1cDMtU5SJ-HeoZJow0fXKZ&opi=89978449
12/22/2023 5:38:48 PM • TDK Electronics... • Answered on Dec 22, 2023
I formatted my TDK 16gb udb drive and now my win7 does not recognize it at all.
Please check if it behaves the same on another computer system. Otherwise reformat it again with FAT32 or NTFS format.
1/1/2017 8:55:32 AM • TDK Electronics... • Answered on Jan 01, 2017
How do I get the film taped on MiniDV60 TDK to my macbookpro?
depends on your camera, firewire if available (4 pin)
6/2/2014 9:50:29 PM • TDK Electronics... • Answered on Jun 02, 2014
How to open vvf video file
Use the following softwares: 1.File View Pro 2.Vi Verify Fingerprint
4/9/2014 1:48:44 AM • TDK Electronics... • Answered on Apr 09, 2014
Works to start with the all of sudden reports parameter problems
Skip Try creating a folder and just copy files. The size of the folder is too big.
4/7/2014 9:50:31 PM • TDK Electronics... • Answered on Apr 07, 2014
How to open a vvf file
Dear, You should switch to VLC Player. Please use following link to download this player for different OS version http://www.videolan.org/vlc/download-windows.html Regards, Rakesh Kumar
3/25/2014 7:29:38 AM • TDK Electronics... • Answered on Mar 25, 2014
Tdk data recovery
You can try 4Card Recovery. It is freeware and very helpful. Detailed steps are here. And it's quite easy. Step1. Download 4Card Recovery on your computer and launch it. Step2. Select the files that you want to recover, or you can choose to recover all. Step3. Choose the 'next' button to scan it and just wait for about ten minutes. Step4. Keep your recovered data or files on other part, this is very important. How to Recover Photos Videos off SD Card after Formatting Unformat SD...
3/16/2014 11:42:54 AM • TDK Electronics... • Answered on Mar 16, 2014
Can not format
at command prompt type chkdsk x: /f /r where x is the flashdrive /memory card
12/31/2013 2:33:30 AM • TDK Electronics... • Answered on Dec 31, 2013
I can't add files to my 16gb TDK gold flash usb
Try RMPrepUSB - Quick Size Test (it will destroy all data but test the drive) or FakeFlashTest. If it tests OK, reformat using RMPrepUSB - Prepare Drive.
11/1/2013 9:21:10 AM • TDK Electronics... • Answered on Nov 01, 2013
Online ups
Hi amin_amin Check to make sure the switch on the side of the card is not locked
5/3/2013 1:52:36 PM • TDK Electronics... • Answered on May 03, 2013
Can't remove write protect from my tdk flashdrive
You have to be the computers administrator to change any values on any hard drive on your computer click start control panel user accounts on the users tab click the name of the computer administrator you must have full control click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select open Right click the icon of your usb drive (It should be E:/ or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control. if you need more help with this post a reply Hope this helps.
1/13/2013 10:44:37 PM • TDK Electronics... • Answered on Jan 13, 2013
How to unprotect TDK RAM disc
click start click to open on my computer you should see your TDK drive E: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select openRight click the icon of your TDK drive (It should be E:/ or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control. hope this helps
9/3/2012 5:50:16 AM • TDK Electronics... • Answered on Sep 03, 2012
How i can see the hidden files in my usb
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts if now you can see your usb drive there might not be any need to do the following click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive I found that you get best results by ticking one box then returning after it has finished then tick the other box then you might have restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7 hope this helps
7/30/2012 6:52:35 AM • TDK Electronics... • Answered on Jul 30, 2012
How to remove write protection
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select openRight click the icon of your usb drive (It should be E:/ or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control. if you need more help with this post a reply
6/16/2012 4:35:04 AM • TDK Electronics... • Answered on Jun 16, 2012
I have tdk flash 8 gb and i left it on the port in my computer when i make new windos to my computre and after that i found my fkash not work
ports (com&lpt) right click update driver if this fails to fix the problemyou might have restore it to its defaults
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7 If you need more help with this post a reply
hope this helps
6/6/2012 11:29:17 PM • TDK Electronics... • Answered on Jun 06, 2012
My TDK 8GB memory stick won't show up on the PS3
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts hope it helps
5/14/2012 12:17:27 AM • TDK Electronics... • Answered on May 14, 2012
Electronics - Others Logo
Popular Tags
1 questions posted
Top TDK Electronics - Others Experts
 Grubhead
Grubhead
john h
David Kassin
David Kassin
Are you a TDK Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • TDK Electronics - Others
Most Popular Question
erasing tdk microcassettes
  • Electronics - Others
