20 Most Recent
Kurio Touch 4S Handheld Questions & Answers
How do i remember my password
Unfortunately, remembering passwords can be tough! If you end up not being able to remember, you'll have to do a factory reset. Judging by how you said it unlocks, I'm assuming you have an Android. Below is how you do a factory reset on an Android device.
Why won't my Kurio 4s charge?
Hi, quite a few things could be the problem, 1, the battery has died....which can be revived with the proper machine, 2. depending on age, it needs to be replaced, 3. your charging port is faulty and needs to be replaced, 4. the wall plug you use can also be worn out and does not make proper contact.....I would suggest that u rather hand it in to a bona fide technician.....
My home screen and reset
Hi, unfortunately its a job for a technician, yr fone has to be connected to a computor to access the security setting. Its a quick job provided you have tornado cables. Take it to yr nearest trusted cellular shop.
Computer is not reading it now
plug it in and check under device manager if it is listed, it may show up with an error as unknown usb device, if so un-install the drivers reboot and plug it in again, if same error check with different lead. if still same errors download drivers and reinstall. if non of that works you may have a faulty conection socket.
Kurio
Hi, I have not had the pleasure of holding one in my hand.....but I am sure that if u play around on the fone u will find quite a lot it can do....select the control panel icon and browse. .if u not sure what u doin...just hit the return icon and start again.....
