20 Most Recent
Panasonic Panafax UF-890 Plain Paper Laser Fax Questions & Answers
Need to re-set a panasonic
Here is what you need to do:
1. You can press the FUNCTION key, then the number 7
2. Then press MONITOR key 4 times
3. Press * then the number 6
4. Scroll down to SHIPMENT SET and choose 2
5. Let the machine reboot
That's it!
8/17/2010 6:52:43 PM •
Panasonic...
Answered
on Aug 17, 2010
FAX machine sends darkened, bad copies
NO! This is the best Fax Machine ever made ! Your scanner is dirty. You can do it yourself.
Remove 3 chrome screws on the left side cover
remove 1 chrome screw below the power cord on the back,
Pull the cover off.
Remove the green plug on the scanner carefully
Remove the 2 chrome screws. Pull the scanner out.
Clean the 2 mirrors throughly.
Reassemble.
5/19/2010 11:16:32 PM •
Panasonic...
Answered
on May 19, 2010
We are not receiving faxes..we keep getting error
The message means:
407 No confirmation from the receiving station for the
previous page sent.
Wait a few minutes and send again.
This can mean 2 things
1) you have not set your fax machine to recieve faxes
2) you need to have your fax machine serviced because the part that makes it pickup a fax has malfuctioned
Clean all paper paths with paper path cleaner.
Unplug and then after 10 seconds replug the fax machine and do a test recieve for it
If all else fails, you may need to call a service person to repair or replace the broken or defective part that recieves faxes.
Hope this helps :)
3/16/2010 4:16:07 PM •
Panasonic...
Answered
on Mar 16, 2010
