20 Most Recent
DeLonghi MG15T SafeHeat Oil Filled Radiator Heater Questions & Answers
What are the instructions for a heller panel heater model hph15led
Hi. Four years late, but do you still need instructions for the Heller HPH15LED panel heater? If so, I can email you a scanned copy. This heater has one of worst user interface designs I have ever encountered on a domestic appliance. Totally non-intuitive -- you really need a manual!! Cheers - Mike
No heat it all, it
To find the problem you will need to pull apart the switch(s) and the thermostat and follow the power to see where it is stopping at...
if there is power to the element and no heat then your done the element is not repairable...
If you find the problem is in the switch or the thermostat, you may be able to find the needed
parts herehttp://www.nelsonappliance.com/space+heater+parts.html
heatman101
Lost the manual
It is working properly. It is suposed to go off and on just like your house heater it is thermostat controled the higher the setting the longer it stays on till it reaches a certain tempeture factory preset
Need an instruction manual for DeLonghi Magnum MG15T
I found the manual at this website:
http://safemanuals.com/user-guide-instructions-owner-manual/DELONGHI/MG15T-_M
Here was the tricky part for me:
The round timer dial has red tabs on the outer edge of it. They all should be pushed inward to allow continuous operation.
From the manual:
Please note when you first use your heater, all the tabs are outwards. You must push in those
tabs for the period that you want the heater to work. (If you want to bypass the timer you must
push all 96 tabs inward).
I hope this helps.
How to i get th case of a delonghi model pacan125hpec open?
:To open the case of a DeLonghi model PACAN125HPEC, locate the screws on the back of the unit and remove them. Once the screws are removed, carefully lift the back panel, being careful not to damage any of the internal components. The case should then open and you can access the internal components.
