Try removing the foil and cutter head. Wait a few minutes and then refit them. It may be on some sort of electronic timer that after so many hours of shaving, the unit automatically comes up with a "change foil" icon and then wont let you use it until its replaced.
pit back in the charge station for at least 4 hours and switch the power on for the charger
many small battery chargers will flatten the battery if the power is switched off
if that fails , contact amazon for a return letter to get you warranty refund
It is a light to tell you to replace your cutter cassette and foil. It will reset after 7 shaves. It usually comes on after 18 months or the cutter is worn. Page 11 in your manual.
All the details Anna, starting with the conclusion.
CONCLUSION. To conclude, diode lasers are better for hair reduction and pigmentation removal, while IPL lasers can be more versatile and can address a wider range of skin concerns. The choice between the two will depend on the specific needs and goals of the patient.
Jan 31, 2023
Braun Series 3 Electric Razor disassembly and battery replacement (original and AA NIMH batteries) (youtube.com)
Braun 9-in-1 Trimmer - Disassembly/Battery Replacement (youtube.com)
Remove the Screws: First, you'll need to remove any screws that hold the device together. Look for visible screws on the casing or housing. Use the appropriate screwdriver (usually a Phillips or Torx) to carefully unscrew them.
Open the Casing: Once the screws are removed, gently pry open the casing. Be cautious not to damage any delicate components inside. You can use a flathead screwdriver or a plastic opening tool for this step.
Access the Battery: Inside the casing, you'll find the battery. Depending on the specific Braun device, the battery may be soldered in place or connected via a connector. If it's soldered, you'll need to desolder the connections. If it's connected via a connector, carefully disconnect it.
Replace the Battery: If you have a replacement battery, insert it in place of the old one. Make sure to observe the correct polarity (positive and negative terminals). Secure the battery back in its position.
Reassemble the Device: Put the casing back together, aligning all the components properly. Screw it back in place.
Test the Device: Once reassembled, check if the device powers on. If it does, congratulations! You've successfully replaced the battery.
I have the same shaver. The motherboard is simple, it has an electronic on/off button, a charger control and that is it. Nothing to program.
Help here, but I would let a Braun Service centre do the job. Getting inside can be tricky.
https://www.google.com/search?q=Braun+Series+5+Shaver+replace+motherboard
Did you change the motor drive unit as well or just the part that holds the foil.
They are supposed to vibrate, but it is difficult to quantify 'excessive'. With my Series 5 and my previous model, I have found Braun Service Centres to be excellent at diagnosis and repair.
https://shaveroutlet.com/braun-pulsonic-motor-drive-unit-p-837.html
The short beep and LED on indicate that the Braun Series 9 charging and cleaning station is receiving power, but is not working properly. First, make sure the station is charged. If the station is charged, but still not working, try unplugging it and plugging it back in. If it still doesn't work, review the user manual to see if there are additional troubleshooting steps, or contact us for assistance. As for the Nakamichi 680ZX deck, the half-speed rotation speed indicator should light up when the rotational speed is selected in the middle. If this does not happen, the drive may be damaged and would need to be repaired.
I have used one of these for over 10 years, and never had it leak shavings unless I am shaving the top of my head after shaving my face. You say you regularly use the cleaning station. It needs cleaning of shavings after every use. I remove the head and tap the shaver and head over the sink after every shave. About every two weeks, I rinse the foil and clean the cutter and shaver top with an old toothbrush and soapy water and leave it to dry.
If your Braun Thermoscan 6022 thermometer is not switching on even after you have replaced the batteries, there could be a few possible causes:
Battery installation: Make sure that you have inserted the batteries correctly, with the correct polarity. Check the battery contacts for any corrosion or debris and clean them if necessary.
Battery type: The Braun Thermoscan 6022 requires two AA alkaline batteries. If you have used a different type of battery, such as rechargeable batteries, this could be the reason why the thermometer is not turning on.
Battery life: Even if the batteries are new, they could be defective or may have run out of charge quickly. Try replacing the batteries with a fresh set of AA alkaline batteries.
Reset: Try resetting the thermometer by removing the batteries for at least one minute and then reinserting them. This can sometimes help to reset the internal electronics of the thermometer.
Faulty thermometer: If none of the above steps work, it is possible that the thermometer itself is faulty. In this case, you may need to contact Braun customer support for further assistance or consider purchasing a new thermometer.
If you have tried replacing the batteries and cleaning the device, and it still will not switch on, there may be an issue with the internal circuitry of the thermometer. In this case, it may be necessary to have it repaired or replaced. You can contact Braun customer support for assistance with troubleshooting or to inquire about repair or replacement options.
I left this for a while and used just one side of the foil, and as I was about to buy a new one I thought I'd give this a try - a weird idea.
Try cutting a pen's spring (at the end) to a similar size to the spring and try putting that under the plastic clip. It's worked for me!
The trimmer is replaceable and can be purchased as an assembly. You will need a T-6 and T-8 torx drivers to take apart the head end of the shaver. Using these tools, remove the swiveling head, the hold down cover over the motor assembly, and then pop off the drive arm for the trimmer. Now the old trimmer assembly can be slid out of the end of the shaver by carefully prying between the case where the on/off button is located and the black trimmer assembly base with a small flat blade jeweler's screwdriver. The new trimmer assembly can then be slid into the case and the shaver reassembled. Just be sure the ends of the retraction spring on the new trimmer assembly are installed over the little chrome retaining lugs for them or your trimmer will not fully retract.
Please get back to us if you have further query or else please accept the solution.
