20 Most Recent
Yamaha CRW 8424 Burner Questions & Answers
Problem with yamaha crw8424s...this device was
Power off the PC, open the case, disconnect burner, power on pc, restart it, power off, reconnect burner, power on. If it work's then you're done. If no, ask your local computer story for a DVD burner
Crw8424s scsi
the drive is ready to give up, when it cant read dvds or cd's and unable to eject because it cannot read tracks and commands it's time to buy a new one, they are very cheap and easy to fit yourself.
Cre8424s scsi
Your CDRW has broken and you will need to replace it.
YAMAHA CRW8424 gives Track following error..
PROBLEM DEFINITION:
Basically, it is a hardware error that occurs when a drive is not capable of following a data track on a CD-R or CDRW or on the other hand, poor power flow may cause the problem
SOLUTION:
1. Try use another disc, a disc with a different band.
2. If one doesn't work, you may have to open your system and use a different power connector, making sure no other devices are using the power connector in the same strand.
3. Lastly, if neither the above doesn't work, you may have to send your drive in for servicing as the head may be dirty or misaligned.
How do i update the drivers for a crw 2100 e burner?
The drivers are part of the operating system. So make sure your operating system Is up to date or upgrade to the latest operating system Windows 10.
If the device does not work with Windows 10 then it's not worth keeping when hardware today is so cheap.
My CD NO HDMI WILL NOT PLAY THRU MY RX-V372 Yamaha RECIEVER with HDMI . So I tried to use rca plugs & no help must have made mistake. Can u help
Based on the information provided, it seems that the CD player is not compatible with the HDMI input on the Yamaha RX-V372 receiver. This is likely due to the fact that the CD player does not have an HDMI output.
In order to play the CD player through the receiver, you will need to use analog RCA cables. Make sure that you have connected the RCA cables to the correct inputs on both the CD player and the receiver. The CD player should be connected to one of the analog audio inputs on the receiver, such as "CD" or "Aux". Once you have connected the cables, select the appropriate input on the receiver using the input selector knob or button.
It is also possible that there may be an issue with either the CD player or the receiver. If you continue to experience problems, try testing each component separately to determine where the issue lies.
In summary, if your CD player does not have an HDMI output, you will need to use analog RCA cables to connect it to your Yamaha RX-V372 receiver. Make sure that you have connected the cables correctly and selected the appropriate input on the receiver.
I cant find a keyster carb kit for a 1981 yamaha xt 25j
1. Contact your local Yamaha dealer or motorcycle shops: They might have access to parts that are not available online, or they could have suggestions on where to find the specific carburetor kit you're looking for.
2. Join online forums or social media groups for Yamaha XT owners or vintage motorcycle enthusiasts: You might find other owners who have encountered similar issues and could provide information on where they found parts or recommend trustworthy suppliers.
3. Widen your search to include alternative brands: While you may be specifically looking for a Keyster carb kit, there might be other brands compatible with your Yamaha XT 25J that are more readily available in your region.
4. Reach out to international suppliers with good reviews: Look for reputable online sellers, like websites or eBay stores with positive customer reviews and good return/exchange policies, even if they are located overseas. Contact them to inquire about shipping to South Africa and any additional costs associated with it.
Yamaha rx-459 turns on & then turns off within 1 second.
The issue you're describing with your Yamaha RX-459 turning on and then off within 1 second is likely a thermal protection problem. The TMP PRT:000 H error code suggests that the unit is shutting down due to overheating. This can be caused by several issues such as a clogged air filter, inadequate ventilation, or a malfunctioning cooling fan. You can try cleaning the air filter and making sure the unit has proper ventilation. If the problem persists, it could be a sign of a malfunctioning cooling fan or another issue with the unit's internal components. I would recommend contacting a professiona
How do i reset my yamaha dx 100 back to original factory settings
yamaha dx100 reset. Press voice switches 1 and 2 while turning power switch on. Display will say test entry?. press the plus/yes button. This will reinitialize all memory to factory settings. Also the lithium ram backup battery voltage will be displayed as check level with a number representing the battery voltage. The number will be 10 times the actual battery voltage. A new battery will display 33 representing 3.3 volts. If your reading is below 22 then your battery is shot and will need replacing and if you turn the unit off it will probably get a scrambled memory again.
Tyros 1 cutting out screen goes grey and restarts
Guessing that some people think a Tyros 1 is a PC or something.
If the Tyros goes blank screen and all the lights go out then it is most likely the REG board (regulators) that provide the 5v and 3.3v. This overheats and the devices shutdown. Quite often this is cured with a restart on more serious cases the regulators need replacing. As they are cheep it is best to replace all while the unit is apart. I am just about to do this repair on a Tyros I purchased the other day.
Yamaha AW4416 retrieved from long time storage hangs up on initializing recorder message when booted. Suspect flat battery in RTC chip?
AW4416 Users - HELP needed!
I think my hard drive crashed or is in trauma! It 'froze up' so I shut it down. When I try to restart it it never gets past the "Initializing the Recorder Section" window. The HD's red light is on without any intermittent blinking.
Is there a trick to get it to boot up so I can back some stuff up?
Last year when I had lots of stuff on the HD I had occasional freeze-ups but it always came back. Then when that project was finished I got all of it off the HD into a backup and the AW has been smooth for more than a year. Recorded a CD for a local string Quartet and everything was good. When that wrapped up I wiped the HD again and started a CD for myself. Not a lot of songs or tracks yet but some stuff I really don't want to lose if possible.
Hard lesson to learn.
Bill from PA, are you out there? any other AW4416 users?
the AW user forum (socialentropy.com) seems dead! I've gotten some great help there!
Thanks
Sourov
