The picture is green
Make sure that the unit is connected to the tv properly. Be aware that most dvd players have six connections. You can connect the unit to the television using RCA cables (yellow, white, red) or RCA sound with component video (white, red, blue, green, and red). When using the yellow-white-red method, the sound is carried by the white and red cables and the video signal is carried by the yellow cable. If you're using the white-red-blue-green-red method, the white and one of the red cables carries the sound, and the blue-green-red cable carries the video signal. This connection uses one cable for the green component of the picture, one for the blue, and one for the red. Make sure that the cables are connected properly and you don't have the two red ones mixed up. Connect Sound-R to Sound-R, component R to component R, etc. If that doesn't work, you may be able to adjust the picture on the tv. There's still a chance that the machine is defective.
