20 Most Recent Waring WMK300 Professional Belgian Waffle Maker Questions & Answers
Waring pro waffle maker WMK300
You are wise to be cautious. The Consumer Product Safety Commission (CPSC) needs to know about this situation, and your input, along with that of others, will be used to start an investigation. Too much excitement just to enjoy waffles!
4/14/2017 9:38:24 PM • Waring WMK300... • Answered on Apr 14, 2017
2answers
Does the waffle maker only beeb 3 times after the first waffle?
It beeps 3 times when each waffle is done.
8/6/2015 5:45:30 AM • Waring WMK300... • Answered on Aug 06, 2015
2answers
Waffles sticks to waffle maker. No matter if i
I notice that this was happening to my waffle maker. I had to remove a thick layer of charred and gummy varnish. This is what the corn oil spray (and maybe sugars) had turned into. No more spray for me.
Now I do not leave the waffle iron hot and empty for long; this alters the oil coating into varnish. Power off until needed for sure.
I apply a thin coating of vegetable (soybean) oil just before adding the first cup of batter. Usually I can get all I need from the cup that measured the oil for the batter! I scrub it around with a boar's hair pastry brush. (Synthetics will melt!) That's usually all I need for a batch of waffles. If they start to stick to one half or the other, I reapply some oil with the brush.
8/5/2015 10:11:53 AM • Waring WMK300... • Answered on Aug 05, 2015
2answers
Waffle stickes
The question is! Was this waffle maker brought into the home new or used?
7/31/2015 6:21:54 AM • Waring WMK300... • Answered on Jul 31, 2015
2answers
Screws that hold bottom and top together have come
I repaired the broken "clamshell" of my Waring Pro WMK300 Professional Belgium Waffle Maker by replacing the original screws with a pair of (black metal) #8 x 1.125 inch flat-head machine screws and anti-vibration lock-nuts. These nuts have a nylon insert to prevent loosening. The assembly is now strong enough to pick up by the handle.
I drilled into the original plastic pits to create through-holes. I chose screws just long enough to fill the anti-vibration lock-nuts without protruding. You will need to hold each nut with a wrench or pliers while turning the screw into the nylon of the nut. Tighten just until the waffle iron assembly is snug, then another 1/8 turn. The torque should increase only during this last step.
The nuts are visible when I flip the iron, but I don't mind - they just remind me that the iron is now stronger than factory design.
5/10/2014 6:39:01 PM • Waring WMK300... • Answered on May 10, 2014
I lost the measuring cup for the waffles. How
3/4 to 1 cup just enough to cover the iron evenly
5/10/2014 12:18:05 AM • Waring WMK300... • Answered on May 10, 2014
Diagram to replace thermal fuse in wmk 300 waring pro
The most common reason for thermal fuse failure is running the iron with the top open, especially when set to a higher number (longer cycle time) and/or not flipping the iron over at the strart of a cycle. Keep it closed except during the 10-15 seconds needed when adding the batter or removing a waffle. Thermal fuse 240C often available on ebay 4/$2 or Amazon 10/$7-$10
4/26/2014 3:01:26 PM • Waring WMK300... • Answered on Apr 26, 2014
Wont tun on
Thermal fuse is blown. Replace
4/26/2014 2:56:28 PM • Waring WMK300... • Answered on Apr 26, 2014
How to replace fuse in a waring pro waffle maker
The fuse is inside, clamped to the bottom iron. Swing the top open. There are 4 small screws, two metric M3 flatheads in the front pivot, two self tapping near the hinge, that hold the bottom iron in place. Often the M3 screws will become fused to the captive nuts. Using the correct size cross-point screwdriver, position it in one of the pivot end screws, and while holding it firmly directly in line with the screw, give the screwdriver a sharp tap on the end of the handle, as if it were a chisel. Repeat with the other front pivot screw. If the screw does not unscrew with a minimum of force, repeat the tapping procedure. If this does not work, use a 1/8" metal bit to drill through the screw heads. Remove the rear screws. There is a spring-loaded pin running through the front pivot halves. Press it in and carefully swing the bottom grid upward. Turn the iron upside down. At the rear of the irons, you'll see where the wires enter from the rear support. Find the metal clip holding down a piece of white rubbery tubing. Remove the screw and clip. The temperature-limiting fusible link is inside the tubing. Push the tubing toward one side until the wire crimp is seen. On the fuse side of each crimp,AS CLOSE AS POSSIBLE TO THE CRIMP, clip the lead. Remove the tubing and clip the other lead. Take two uninsulated crimp-style spade lugs for 20 ga wire, and clip off the spade ends. The crimp ends will be your new crimp connector. From the iron's leds, remove the old crimps. Strip just enough jacket for the exposed wire ends to match the length of the new crimp connectors. Take the stripped lead that is toward the iron's terminal, insert into a crimp connector. Insert one end of the new fuse in the other end so the overlapping leads each just reach the opposite end of the connector. Crimp in place. Slide the tubing over the fuse and push it toward the iron. (The loom tubing on the other wires will compress to permit this). Connect the other end of the new fuse to the remaining stripped wire with the second crimp connector. If you had to drill out the M3 screws (I did), use a vice grip wrench to grasp the remaining shaft with as little compression as possible and remove. The threads of the captive nuts should be ok. Replace the screws with M3 flat head crosshead screws and antiseize compound of the threads. Notes: 1. The most common reason for thermal fuse failure is running the iron empty with the top raised. 2. I got replacement fuses via ebay 4/$2, M3 screws at Ace Hardware @$0.19. 3. All the wires inside the iron are insulated with high temperature silicone or non-melting jackets. Stripping requires an electricians stripper/crimper with a 20-22 ga cutter. More force is needed to strip these wires than you might expect. You'll find it much easier if you hold the wire being stripped with a pliers while stripping.
4/26/2014 2:50:10 PM • Waring WMK300... • Answered on Apr 26, 2014
How many is 2/3
Look at a photo of yourself with your parents. The fraction of that group that would be embarassed to ask your question is 2/3.
4/26/2014 1:57:45 PM • Waring WMK300... • Answered on Apr 26, 2014
The support pillar at the clamshell end loosened. When I looked at it closely the plastic bracket that holds the pillar to the base is broken in half. Where can I get a replacement. (Not available o
The only way to get this part is from another broken unit. If it were me, I'd try using an epoxy in combination with something to act as a splint, like a piece of Popsicle stick or a piece of metal, positioned inside the bracket. The bottom of the unit can be easily removed -8 screws, 4 under the feet. I got my WMK300 at a local Goodwill store for $5. It worked fine for a few months before the temperature sensor fuse needed to be replaced ($2/4 at eBay).
4/26/2014 1:54:57 PM • Waring WMK300... • Answered on Apr 26, 2014
How to fix waring pro waffle maker- it does not
check out my other FixYa answers for the Waring Pro WMK300.
4/13/2014 5:55:57 PM • Waring WMK300... • Answered on Apr 13, 2014
2answers
Looking for a thermistor. Only part number on it
Hello Pfeuti,
The only way to fix the unit you have is to purchase the whole assembly. Here is a link to all available parts that can be purchase in a blown up form http://www.ereplacementparts.com/waring-wmk300-waffle-maker-parts-c-120019_120354_120541.html
Thank you for choosing FixYa.com
Justin
4/13/2014 5:08:01 PM • Waring WMK300... • Answered on Apr 13, 2014
Waring WMK300 Professional Belgian Waffle Maker Logo
138 questions posted
Top Waring Kitchen Appliances - Others Experts
Paul Carew
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Waring Kitchen Appliances - Others
Most Popular Question
diagram replace thermal fuse in wmk 300
  • Kitchen Appliances - Others
