If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Circuit diagrams to many brand TVs and others are given.
The TV might need a soft reset which is unplugging the power cord for 60 seconds and plug back. Try that, Or the worse case is that the MAIN BOARD inside the set needs replacing which I just did an online search and found none available.
our MacBook may or may not have a DVI/VGA output socket and only USB-C, if modern.
Does your monitor have similar input sockets, if not, it won't work.
the very beginning find and select Settings. ... Afterward, scroll down to Language & Input and choose it. ... Then select from the top of the screen Language.
Not sure what you mean by 4Glite> 4G and LTE as network standards. Or do you mean 'light', the lightbulb feature? All Konkas have a model number of letter/number and you aren't telling us that.
Goggle
make model manual
https://www.google.com/search?q=konka+4glite
People still use Flip Phones? :>D
https://www.google.com/search?q=konka+4g+flip+phone+manual
Duplicate question deleted. Refresh page to see you question.
Question edited for clarity.
It is unusual to have nothing which leads me to believe the power board has failed. Try a power reset, remove the wall plug for 5 minutes. Plug back in, press and hold the power button on the set, for 12 seconds. If that doesn't fix it, take it in for repair. This is a high specs, low budget make, NZ$928.00 new. The model is only available in New Zealand. We are in North America.
They are known for failing with no picture, but have sound.
https://www.google.com/search?q=Konka+KUD50GT776AN+no+picture%2C+no+sound
I would check the batteries position in the remote. Usually one points up, the other points down. If both are placed in the same direction, they cancel each other out. That could drain the batteries too. If Up/Down doesn't work, try Down/Up. Good Luck.
please ensure that your mute and volume down buttons are not currently stuck on your remote. Then, you can restart the tv and check for sound again. Please check multiple channels. If it's not working, please use the volume keys on your tv to help get the sound back. If this fails, please remove all the tv accessories and check for sound Again. Otherwise, please factory reset the tv in order to get back the sound.
Thank you.
No it won't be a software issue. If it worked before, it should work the next day without needing software. It has failed and needs repairing.
This is typical of reviews
Is Konka a good TV brand?
TV is complete garbage with no product support or updates of any kind, even security updates after over almost 2 years, had an issue with the TV and was unable to even get support from Konka, I'd advise to avoid this brand at all costs, looked great to start, but after having it for a while and seeing issues with the ...
It is a TV and not any kind of PC>
Konka 49"-Ultra HD 4K Smart LED TV -UDE49HR314ANTS 3840*2160P Android television-Black/
smart OLED TV.
SOLD IN KENYA? Africa?
what does normal TV mean, HDTV antenna or cable box,?
is wifi dead at home to TV or wired Ethernet? to TV to router.
Not told are all internet PLAYER APPS dead on the smart screen?
if internet is dead on the TV just post that/.
to use streaming TV one needs internet connections;
like Tubi or Netflix or HULU or VUDO or 100s of others. youtube?
what this this google thing?
google applications????
name one?
in the TV click settings and nework
is that all good>? connections.?
Hi there, buddy.
Just gonna say that most tv's still use FAT32 as their read mode, so if your external drive is NTFS, you're outta luck. Sucks to be you, unless you have a big thumbstick you want to format to FAT32, so you can copy/paste'em, and watch them like basic PVR.
Cheers from NZ :)
