20 Most Recent Scotch Super Glue Liquid Plus, .07oz, Super Glue Liquid Questions & Answers
2answers
I have some spots of superglue on a lovely shirt, is there a substance which will remove it?
Probably not without damaging the fabric because these glues are so hard. 2 products I would try if you can get them where you are: 1. tea tree oil 2. Eucalyptus oil. These will react with normal glues and break them down without harming the fabric or taking out any colour. I have not tried either of them with any of the super glues so I cannot say if it will be successful with such super tough products. I would also test them on another piece of similar fabric spotted with the glue before using them and that will tell you if they will work on the SG. Other than that you would need to try various strong solvents to see if they would break down the glue and enable you to remove it. The problem is you may end up with a stain, loss of colour or some damage to the fabric if it is a sensitive fabric. If you test some of these on an old piece of similar fabric you have spotted with the glue you will be able to see which one worked without harming the fabric. If you can buy a bottle of dry cleaning fluid (I cannot remember the technical name) you may be able to move it using a liberal amount of that product or just soaking the areas with the spots in the fluid. Be careful handling it as it is pretty toxic. Applying steam (from a boiling kettle ) to areas of the fabric affected may soften the glue a little and enable you to roll it off the fabric if it is not heavily impregnated. Whilst this can work with some of the softer glues it may not with the SG. I would also test it first on another piece of fabric
1/11/2016 1:25:36 PM • Scotch Super... • Answered on Jan 11, 2016
I have a Scotch Laminator Model # TL1302 which has suddenly stopped heating up. What could cause this to happen?
There could be a few possible reasons why your Scotch laminator has stopped heating up. Here are some things you can check:
  1. Power supply: Make sure that the power cord is securely plugged into the wall outlet and the laminator. If it is plugged into a power strip, try plugging it directly into the wall outlet to eliminate any potential issues with the power strip.
  2. Overheating protection: Many laminators have an automatic shut-off feature that kicks in when the machine gets too hot. Wait for the laminator to cool down and try turning it on again.
  3. Thermal fuse: The laminator may have a thermal fuse that has blown due to overheating. This fuse is designed to cut off the power to the heating element if the temperature exceeds a certain level. If this is the case, you will need to replace the fuse.
  4. Heating element: The heating element itself may have failed. This is less likely than the other possibilities, but it is still a potential issue. If this is the case, you will need to replace the heating element.
If you have tried the above steps and are still having issues with your laminator, it may be best to contact the manufacturer or a professional repair service for further assistance
3/15/2023 4:47:59 AM • Scotch Office... • Answered on Mar 15, 2023
Scotch TL902 Laminator - Ready light keeps blinking blue and doesn't heat up
here's how I fixed a no heat problem on the Scotch TL901 https://youtu.be/-H7BQMRgF8k
8/25/2021 12:02:21 AM • Scotch Office... • Answered on Aug 25, 2021
2answers
Why won't my scotch laminator pull the laminating pouch into the laminator
Maybe it just doesn't heat up to a needed temp
3/25/2020 2:38:54 PM • Scotch Office... • Answered on Mar 25, 2020
2answers
How to install cartridge for a Scotch LS960 Laminating machine
load from rear moving tangs and flap push in wheel loads on to plate on its own
1/17/2019 11:21:46 PM • Scotch Office... • Answered on Jan 17, 2019
4answers
How many ounces of body lotion is 200 ML ?
200 ml is about 6.76 US ounces or about 7.04 UK ounces.
4/24/2024 8:53:54 PM • Office Equipment... • Answered Yesterday
How do these points equate to money?
No money ever! There is no payment made for answers on Fixya, points don't mean prizes, they are just for fun. ADMIN Andrew
  • Answers: 65,820 and not a penny per Answer.
Head over to www.justanswer.com they pay lots of money because they charge for people to ask a question. ..
4/19/2024 9:45:02 PM • Office Equipment... • Answered on Apr 19, 2024
Error code e000350-0002
'Make model (what it is)' is needed in questions like this, and in fact ALL questions!! But we can just guess.
Error Code Ir 3300 e350-3000 and e350-00002
Copytechnet https://www.copytechnet.com > ... > Canon May 1, 2018 - Put ALL the original boards back in the machine. Go to service mode level 2 & perform E355 clear. If this fails your machine is scrap. CANON iR2200 Error code E000350-001 Jan 22, 2007 error code :E0003-0002 canon IR 2880i Feb 5, 2018 Canon IRA C5540I Code E000354-0002 Sep 23, 2021 E000350-3000 on IRC4580 Sep 25, 2017 More results from www.copytechnet.com
Canon iR Advance 4245 - E350-0002
PrintCopy .info https://printcopy.info > code=E350-0002 Canon iR Advance 4245 ; Code: E350-0002 ; Description: System error ; Remedy: Contact to the sales companies. ..
4/19/2024 5:37:38 PM • Office Equipment... • Answered on Apr 19, 2024
E6 on my ISMART 500 trojan. How do i fix it please
This link is the best I can come up with: How to fix E6 & E7 on Trojan treadmill solved!! (youtube.com)
4/19/2024 12:27:09 AM • Office Equipment... • Answered on Apr 19, 2024
2answers
Error code Z08-1090
I need help I have an error on my ComColor 7050 Z08-1090
4/18/2024 11:40:08 AM • Office Equipment... • Answered on Apr 18, 2024
2answers
How do I fix this error SEr on conlog prepaid meter
Call your supply company.
4/17/2024 1:47:07 PM • Office Equipment... • Answered on Apr 17, 2024
Scotch Super Glue Liquid Plus, .07oz, Super Glue Liquid Logo
2 questions posted
Top Scotch Office Equipment & Supplies Experts
Marty Warge
ADMIN Andrew
ADMIN Andrew
Alex Kimuyu
Are you a Scotch Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Scotch Office Equipment & Supplies
Most Popular Question
some spots superglue lovely shirt
  • Office Equipment & Supplies
