20 Most Recent
Gbc 1702760 - Heatseal H212 Laminator Questions & Answers
How do I clear the cutting roller axle on my GBC Shredmaster 950 paper shredder? It has long strands of cut paper wrapped around the end of the axle.
Fixing paper jams in a shredder can be hard, but with care, you can fix it safely. Here's a guide: 1. **Stay Safe**: Make sure the shredder is unplugged or off before clearing any jams to prevent accidents. 2. **Get to the Blades**: Most shredders have a top part that holds the blades. Depending on your type, this might mean taking off a cover or lifting a piece of the shredder. Look at the user guide for your GBC Shredmaster 950. 3. **Find the Jam**: See where the paper is wrapped around the roller axle. Use a light if needed. 4. **Clear the Way**: Gently use your hands or tweezers to take off the paper wrapped around the axle. Be careful not to harm the blades or other inside parts. 5. **Look for More Stuff**: Once you've fixed what you can see, check the blades and area for any leftover paper or stuff. Use air or a vacuum to remove any tough pieces. 6. **Put It Back Together**: After making sure the blades are clear, put the shredder back together as the manual says. 7. **Test It**: Plug in or turn on the shredder and try it with a bit of paper to make sure it works well and there are no more jams. Remember to check your user manual for details and safety tips for your shredder. If you're not sure or not comfortable, it's best to ask the manufacturer for help.
GBC ezload laminator displays code 3 and stops after 5 seconds
When a GBC EZLoad laminator displays code 3 and stops after 5 seconds, it typically indicates an error or issue with the laminator. Code 3 is a general error code that can have different meanings depending on the specific model and manufacturer.
To troubleshoot the problem, here are a few steps you can try:
1. Power off the laminator: Turn off the power switch and unplug the laminator from the power source. Let it sit for a few minutes to allow any residual power to dissipate.
2. Check the laminating pouch: Make sure the pouch you're using is compatible with your laminator. Ensure that the pouch is not too thick or too thin for the laminator's specifications. It's also important to check if the pouch is inserted correctly and aligned properly.
3. Clear any obstructions: Inspect the laminator's feed area and remove any jammed pouches or debris that might be causing a blockage. Gently clean the rollers and ensure they are free from any adhesive residue or dirt.
4. Reset the laminator: Some models have a reset button or a reset procedure that can be followed to clear any temporary errors. Consult the user manual or manufacturer's website for instructions specific to your GBC EZLoad laminator model.
5. Test with a different pouch: Try using a different laminating pouch to see if the issue persists. This can help determine if the problem lies with the pouch or the laminator itself.
6. Contact customer support: If the problem continues after attempting the above steps, it's advisable to reach out to the GBC customer support team or the place of purchase. Provide them with the specific error code (Code 3) and a detailed description of the issue. They should be able to provide further assistance or recommend a solution.
Remember, these steps are general guidelines, and the specific troubleshooting process may vary depending on your laminator model. Always refer to the user manual or contact customer support for accurate information and instructions.
