20 Most Recent Roberto Cavalli RC 451 Sunglasses Questions & Answers
My sunglasses frame broke i need address for
sir
your sunglasses are branded Roberto Cavalli RC 451 Sunglasses so i request you to take the sun glasses to the show room where you brought it . they will have solution to your problem for sure.
if youare satisfied with my answer plsvote 3 thumbs up for it
11/21/2014 7:21:39 AM • Roberto Cavalli... • Answered on Nov 21, 2014
My roberto cavalli sunglasses continue to loose
hi
i understand ow much irritation it must be to you,please try approaching any other dealer with your lens if you are under warranty period i think you get it replaced .if it not under warranty and if the dealer dont stand by it .please try visting site which dealer with sunglasses replecement parts i think they can provide you solution and it will cheap
thank you
12/28/2010 7:05:08 AM • Roberto Cavalli... • Answered on Dec 28, 2010
2answers
What is the warranty for roberto cavalli sunglasses?
Look at your warranty card and it will better you go for Shade Tree Sunglasses which provides you sunglasses with warranty.
2/28/2023 4:35:42 AM • Roberto Cavalli... • Answered on Feb 28, 2023
Lost screw of my Cavalli Sunglasses
Sorry to hear that.
12/29/2015 7:29:47 AM • Roberto Cavalli... • Answered on Dec 29, 2015
2answers
Roberto cavali sunglasses spare parts
I broke the rod of my roberto cavali,korumba sunglasse
/uploads/images/roberto-cavali-sunglasses-spare-parts-34960726-2-1.jpg
2/9/2015 8:05:32 PM • Roberto Cavalli... • Answered on Feb 09, 2015
Oakley screw fell out
Here are a few steps you can take to address this issue: Tighten Existing Screws: First, try tightening the hinge screws. Use a small, flat-head screwdriver to remove the rubber screw cover located on the hinge area. Then gently tighten the screws that hold the hinge in place. Be careful not to over-tighten them, as this can strip the screws. Check for Replacement Screws: You can search for replacement screws specifically designed for Oakley Tie Breaker sunglasses. Some online retailers offer Oakley replacement screws that can help fix the problem. Look for screws that match the original ones in terms of size and design. Sunglass Repair Kits: Consider using a sunglass repair kit. These kits often include various sizes of screws and tools for repairing sunglasses. You might find a suitable replacement screw in one of these kits. Remember to handle the screws carefully and avoid overtightening. If you're unable to find a replacement screw, reaching out to Oakley customer service.
4/20/2024 10:49:19 PM • Clothing... • Answered on Apr 20, 2024
2answers
What do you pack in your purse?
Here are list of things you can carry in your purse: A makeup bag. I do my makeup on the go a lot, so a makeup bag is necessary for me. A pair of earrings / jewelry. Hair ties and bobby pins. A hair brush. A notebook / sketchbook. A pen and a pencil. Pack of tissues.
4/17/2024 7:09:47 AM • Clothing... • Answered on Apr 17, 2024
3answers
How to clean white shoes properly?
Cleaning white shoes can help maintain their appearance and keep them looking fresh. Here's a step-by-step guide on how to clean white shoes properly:Materials you'll need:1. Mild soap or detergent2. Soft brush or toothbrush3. White vinegar or baking soda (optional)4. Water5. Clean cloth or sponge6. Old newspapers or paper towels Steps:1. Remove Loose Dirt: Knock your shoes together or use a brush to remove loose dirt and debris. You can also use a soft cloth to wipe away any surface dirt.2. Remove Laces: Take off the shoelaces. You can either clean them separately or replace them if they are too dirty or worn.3. Pre-treat Stains:If there are stubborn stains, pre-treat them with a mixture of water and a small amount of mild soap or detergent. You can also use a paste made from baking soda and water for tougher stains.4. Soak Laces:If you removed the laces, soak them in a mixture of warm water and mild soap. You can also add a bit of baking soda or white vinegar to help with stains. After soaking, scrub them with a brush or toothbrush, rinse, and let them air dry.5. Wash Shoes: Mix warm water with a small amount of mild soap or detergent. Use a soft brush or toothbrush to scrub the shoes gently. Pay extra attention to stained or dirty areas. Be careful not to use a brush with stiff bristles, as it may damage the shoe material.6. Rinse Thoroughly:Wipe off any soap or detergent with a clean, damp cloth or sponge. Make sure to remove all residue.7. Dry Properly:Stuff your shoes with crumpled newspaper or paper towels to help them retain their shape and absorb moisture. Let them air dry in a well-ventilated area. Avoid direct heat sources like radiators or sunlight, as this can cause the shoes to yellow.8. Clean Soles:Clean the soles of your shoes separately. You can use an old toothbrush or a small brush to scrub away dirt and grime. A mixture of water and mild soap or a specialized sole cleaner can be effective.9. Protect and Maintain: Consider applying a stain and water repellent spray to protect your white shoes from future stains. Regularly clean your shoes to prevent dirt buildup.10. Polish (for Leather Shoes):If your white shoes are made of leather, you can use a white shoe polish to restore their shine. Make sure to follow the instructions on the polish container.Remember, prevention is key. Try to avoid wearing your white shoes in muddy or extremely dirty conditions, and clean them regularly to keep them looking their best.
4/17/2024 7:05:52 AM • Clothing... • Answered on Apr 17, 2024
I want to engrave my name on the back side of a necklace, how?
I suggest that you will get the necklace first and then take it to the jeweler for engraving.
4/7/2024 4:18:13 AM • Clothing... • Answered on Apr 07, 2024
2answers
What is a fascinator? So many people are talking about them on TV etc
A fascinator is a a headpiece that is a modern alternative to a hat. It's usually worn as a large, feathery decoration that is attached to a hairband or clip.
3/23/2024 2:56:59 AM • Clothing... • Answered on Mar 23, 2024
2answers
How much would getting a wedding dress made cost?
The cost of getting a wedding dress made can vary greatly depending on factors like the design complexity, quality of materials, and the expertise of the designer. On average, it can range from a few hundred to several thousand dollars. It's important to consider your budget and discuss pricing with the designer to find the best option for you. For best designer lehengas, saree and ethnic wear you can check Mirraw Luxe online. Visit now: https://www.mirrawluxe.com/trends/wedding mirrawluxe_419039130_368272405952318_133677031493383980_n-1o5ccob0r24b1hj0bygsf3dd-d-0.jpg
3/8/2024 1:22:32 PM • Clothing... • Answered on Mar 08, 2024
Is there such a thing as a bridal fascinator?
Yes sure.Lots of brides now are using fascinators to accessorize their dresses in amodern way without looking like they are wearing a proper hat.
Try lookingat these sites to get some ideas:
http://www.weddingfascinators.co.uk/bridal-hair-accessories.html
2/25/2024 10:10:29 PM • Clothing... • Answered on Feb 25, 2024
I bought some rodenstock Wimbledon sunglasses
1/27/2024 9:29:12 AM • Clothing... • Answered on Jan 27, 2024
7answers
Where can convert european shoe sizes to american?
Here you may find a convertion table for shoe sizes.http://www.dancesport.uk.com/shoes/conchart.htm
1/10/2024 2:34:01 PM • Clothing... • Answered on Jan 10, 2024
The frame on my prescription eye glasses broke
Try fixing it at home with some DIY elements.
9/27/2023 6:56:36 PM • Clothing... • Answered on Sep 27, 2023
Toyota Tazz - External Left Hand side Rear view
What about it
9/2/2023 9:39:39 AM • Clothing... • Answered on Sep 02, 2023
How can i tell if i have a fake tonino lamborghini
6/28/2023 9:28:59 AM • Clothing... • Answered on Jun 28, 2023
I'm looking for a Coach Kristin Strap in Raisin -
4/14/2023 11:49:41 AM • Clothing... • Answered on Apr 14, 2023
2answers
How do I use
4/3/2023 2:14:03 PM • Clothing... • Answered on Apr 03, 2023
Roberto Cavalli RC 451 Sunglasses Logo
Popular Tags
2 questions posted
Top Roberto Cavalli Clothing Accessories Experts
ADMIN Andrew
ADMIN Andrew
john h
Don A
Don A
Are you a Roberto Cavalli Clothing Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Roberto Cavalli Clothing Accessories
Most Popular Question
  • Clothing Accessories
