20 Most Recent
Maxis Sims - People Simulator from Creator of SimCity for Windows Questions & Answers
How to install the sims with the disk
Usually you start by the main-game - if the main-game is installed you continue with the addons. Remember: Install the oldest addon directly after the main game.
How to download the sims with disk
Insert the disc into your disc drive, and locate the game in your C:Drive then move the game to you respective hard drive and launch the executable file. The game should automaticly download from there.
I have a sims cd but lost the reg key. how do i
If the key wasn't stored, then you are out of luck. I always store my keys in a backup off of my computer such as on an encrypted USB drive. (keep one in the safe, those keys are valuable!) Sorry for the bad news :(
Will 83069-U18 controller work on a PS2 please?
The Nyko Core Controller 83069 is a versatile controller that is compatible with both PCs and PlayStation 3 consoles1. However, there is no specific information available about its compatibility with a PlayStation 2 (PS2). It's always a good idea to check the product's user manual or contact the manufacturer for the most accurate information.
If you have a PS3 or a PC, you should be able to use this controller. Please note that compatibility can sometimes depend on the specific model of the console and the controller's firmware version
What does code 71 on a 2013 paccar 587 mean?
Its when the Shift attempts to pull out of gear, but the Gear Position Sensor indicates that the transmission was unable to disengage that gear. and detected a system failure, and unable to detect the cause.
Solitaire Customer Service Call 1-8O5-225-6690
We are 24 Hour Available Call Now
Well you really didn't loose them.
What happens is Hp puts in the software of a whole bunch of games where after time you have to go to their site and purchase their games.
Well there are other FREE sites to goto to find Solitaire, free cell, Spyder solitaire and such.
I also think that they meybe hidden files in Windows, but to find them you have to remove Hp games and then do a search
When the game turns on
Pokemon crystal is a Game boy color game, there for it will not run the original Game boy.
What are some good catering services?
I recomenr you Alchemiq, it is a quality caterers https://alchemiq.com/catering-nyc/. They offer gourmet appetizers, fancy food stations, upscale cocktail catering, and event design
Recommended System Requirements
Find out if you can run that game on your PC Learn about. System Requirements Lab
www.systemrequirementslab.com
you can find here the minimum and required system requirements for most of the games and the updates needed for you to download to make the games run on your system.
Update profile
Clear your question, because which types of profile update. Then i better answer given.
Thanks.
