20 Most Recent
Verge VMP508 CD Player Questions & Answers
Changing the clock
Wow I know its been a while but I can tell you how to change the clock on your radio. It can be done while the radio in on or off. To simplify this please turn radio off. The incorrect time should be displayed. There is a button that is the display (disp) located in the middle right of the face.( If for some reason the time is not displayed, press the disp button once or as many times needed until the time is displayed. Now let it go and continue from there.) Press and Hold this button down until the time begins to blink. Once it begins to blink let go of the disp button. Now the next button you are going to use is the 'skip' button (>>I) for the hr only and the (I<<) button for the min. You cannot go backwards only forward. You must observe the correct time of day or am/pm. The >>I and the I<< are far right and vertical to each other. Because one is for hr and the other is for min you can not go backwards only forwards. So hold down the hr button until it is the right am or pm and the right hr. The min is simpler since you don't have to worry about am or pm, just depress the button once it reaches the right mins in the hr. Hope this helps
I lost my adaptor for the recever of my radio
I am no way affiliated, but I get my car audio from Crutchfield and they have a HUGE range of adapters that come gratis with car audio purchase. However, you can get these adapters separately as I did when installing my wife's car audio. www.crutchfield.com.
Vmp508 verge cd player/in dash car stereo
Mine was doing the same thing for a while. I put in one of those special CDs that have little tiny brushes on them that are used to clean the laser. And after that it worked. It still does it every once in a while, but not very often. It seems to like mp3 discs more than regular CDs. But be sure to DISABLE MULTISESION when you burn your mp3s. Otherwise it will DEFINATELY give you the error 2 message.
No display
Hey Guys ,
I was wondering if the solution given over here helped you. I am also having the same issue and my display is somewhat gone. It sometimes comes up on tapping the screen which makes me feel that the solution proposed over here could be of help.
Wiring
red is the hot wire black the negative orange or yellow the battery, the greens or blues or greys are the speakers the wires with a this thin black line are negative speaker
How to install car stereo / CD / MP3 ?
go online to cicuit cty or look up online a store where they carrie that model they ussualy have a place wher u can input ur car model to see if it will fit
Sony CDX - RA700
sounds like you dont have power to clock or memory wire (yellow)..also if it is a faceoff ..make sure contacts on both radio and face are clean ..
Re-setting preset stations
manualy select the station you want, then press and hold the station pre set number on you unit for approximatly 5 seconds. job done
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
