20 Most Recent Agfa SnapScan E25 Flatbed Scanner Questions & Answers
Open the log file
Looks like you've confimed that there's an issue with the scanner (which might be up to 17 years old) so it may be time to let go. I see from the specs that the scanner also supports Windows, so maybe before you send it to that great recycle bin in the sky, you give it one more shot at life, by connectiong it to a Windows machine. http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000034806.pdf
1/9/2018 5:39:58 AM • Agfa SnapScan... • Answered on Jan 09, 2018
How do i get my
Hi clivegillyve
It's impossible under Windows 7 . There is no more support from AGFA .
Use a virtual version of XP on your new machine : http://download.cnet.com/VMware-Player/3000-2094_4-10470784.html
Best regards ,
fanaudi .
9/5/2011 5:41:42 PM • Agfa SnapScan... • Answered on Sep 05, 2011
I am running win-7 x64.
Hi koppeling
There is no direct solution since Agfa doesn't support your driver anymore after XP .
Install a virtual version of XP on your PC with FREE WmwarePlayer :
http://download.cnet.com/VMware-Player/3000-2094_4-10470784.html or via Microsoft if you are using Ultimate or Professional .
Otherwise , you 'll need to replace your device by a W7 compatible one .
best regards ,
fanaudi .
8/25/2011 6:30:53 AM • Agfa SnapScan... • Answered on Aug 25, 2011
0answers
Scanwise cannot find the current colorsync system
Uninstall the scan software and install the snow leopard software not using the upgrade path. If the problem persist, install only the orignal scanner software.
5/25/2011 1:54:00 PM • Agfa SnapScan... • Answered on May 25, 2011
0answers
2answers
I need a driver for this scanner AGFA SNAPSCAN e25
Hi i hope u 'll be fine
You can easily and free download the driver from here
  • ftp://ftp.agfa.be/DRIVERS/softpack/scanners/PC/ScanWise/2.0.0.9-e25.exe
After clicking Download 'll automatically start after few seconds. download then install it on your PC and Enjoy
I hope this solution will helpful for u. Best of luck
Kindly keep thumbs up in do Rating if it is helpful
Regards
4/30/2010 5:35:38 PM • Agfa SnapScan... • Answered on Apr 30, 2010
Driver for Flatbedscanner22 for OS windows 7
About Agfa Snapscan E25:
Agfa discontinued its DTP scanner product line (SnapScan, DuoScan, Horizon and Arcus range) and digital cameras (ePhoto, ActionCam, StudioCam) at the end of 2001. At this page is the link for downloading the last valid drivers for your scanner, supporting up to winXP. Try, if you are lucky it may work with Win7
About Acer Aspire 3050:
This laptop has no drivers for Win7 (that's what acer says, not me). Here is the last driver for your camera supporting up to Vista.
In my opinion try the latest drivers that I send you, since there is nothing to loose.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
2/25/2010 2:00:24 PM • Agfa SnapScan... • Answered on Feb 25, 2010
I work with Mac OS (Snow Leopard) and my Mac don't
Snow Leopard has a bunch of drivers built in to control various printers.  If it doesn't recognize the printer, then you will have to go on Agfa's web site to see if they have a printer driver compatible with Snow Leopard.  Keep in mind that Snow Leopard is a new OS and that printer manufacturers will take some time to update their programs and drivers to run on it.  If you don't find a driver then, you got to use a different printer or downgrade your OS to one that will run the printer.
11/6/2009 1:38:40 PM • Agfa SnapScan... • Answered on Nov 06, 2009
4answers
Benq scanner 5250c driver for vista
Hi alls, this is my solution for Benq Scanner 5250C under Win Vista and Win 7 [both 64bits and Ultimate version]; [sorry for my English Im Spanish]
- Disable signature verification of drivers;
* Start Menu à Run and type this command; bcdedit /set nointegritychecks ON
- Restart the computer.
- Install this driver from Benq homepage; [scanner_sw_5250c_v6.3.zip]
Support page; http://benq.co.ae/support/downloads/downloads.cfm?product=558
Driver to download; ftp://211.78.86.210/scanner/drivers/5250c/scanner_sw_5250c_v6.3.zip
Install it with Administrator privilege [right mouse button …] press yes when ask if you want install unsigned driver.
Run Mirascan driver, it say that not found any scanner, close this application, unplug the USB scanner and plug again the USB cord. Run again Mirascan … and calibration will start and all possibilities are ok.
Remember to enable the signature verification of drivers;
- Run; bcdedit /set nointegritychecks OFF
- Restart the PC.
by JoinMA
bibi.
10/14/2009 7:40:57 AM • Agfa SnapScan... • Answered on Oct 14, 2009
Acer fladbedscanner22 wont work
that is right cause you need disk to get it to work and you dont have it,, so go to website and find the scanner number you are using and download the driver fo it
8/10/2009 3:45:00 AM • Agfa SnapScan... • Answered on Aug 10, 2009
Agfa Snapscan e25
cant find updated drivers for agfa E20 flatbed scanner?
3/5/2009 6:30:08 PM • Agfa SnapScan... • Answered on Mar 05, 2009
Drivers for vista
The latest drivers for your scanner are here
http://static.agfa.com/digicam_scanner_drivers/scanner/snapscan_e25/index.html
If this doesn't work then you might be out of luck, Unfortunately, AGFA decided to stop manufacturing and supporting scanners in 2001 so it is unlikely they will release a Vista specific driver
4/4/2008 9:47:45 PM • Agfa SnapScan... • Answered on Apr 04, 2008
Drivers for Vista
With the Computer.
Go to Start/programs/accessories/system Tools/Compatibility and attempt to reset the computer to the Windows mode the Scanner was made for.
Be aware however that Scanners made for use with Win 95/98/ME operate under DOS commands and 2000/XP/Vista work on the NTFS system so there is a hardware not software problem.
You will I feel wind up buying a Vista Compatible Scanner
12/27/2007 9:01:20 AM • Agfa SnapScan... • Answered on Dec 27, 2007
Agfa e25 scanner
Scanners tend to be made not to be dismantled,
So this is a problem you will have to figure your self or buy a new scanner
12/27/2007 8:58:18 AM • Agfa SnapScan... • Answered on Dec 27, 2007
Hardware problem
Did you apply the lock in the move? Take a look under the base- also check the manual. Failing that then one can only assume it has had a bump in the move. Depending on age you could try the makers- maybe a warranty hope there. Certainly the tech support may have some answers as may be here http://www.fixya.com/support/p168051-agfa_snapscan_e25_flatbed_scanner/solutions
5/18/2007 3:00:46 PM • Agfa SnapScan... • Answered on May 18, 2007
0answers
Agfa SnapScan E25 Flatbed Scanner Logo
23 questions posted
Top Agfa Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
john h
Are you an Agfa Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
SnapScan Agfa
  • SnapScan Agfa
Most Popular Question
get
  • Office Equipment & Supplies
