20 Most Recent
Kensington SD400V USB Docking Station with VGADVI and Ethernet Questions & Answers
Will a kensington universal docking station work with my sony vaio pcg-7d2l
Yes it should if you are running Windows XP, Vista, 7 or 8. You just connect to the unit using a spare USB port on your laptop and a plug-plug USB cable. It has it's own power so you'll need a mains socket. This means you can unplug your laptop and leave any devices charging on the docking station USBs. Your laptop should auto-instal the station. I believe there is a table/support available which combines with this unit. There a varying prices for this unit so look around.
Good Luck
I have lost my pin for my kensington bluetooth keyboard. How do I start again
Power on keyboard with 5 seconds button on. Keyboard will start with LED slow two flash mode.
Go to Device menu and "Add a device". Select Keyboard.
On the UI keyboard, input "0000" (no enter), and touch "add".
Then on the physical keyboard, input "0000" + Enter.
It should make start connecting.
The UI changes into connecting view. But it already connected.
You can test with pushing "Windows Key" on the physical keyboard.
After connected, both LED on keyboard was automatically turned off. It is still working normally.
My kensington trackball mouse will not work on your games.
Long ago Kensington never made the change to their driver when Microsoft went from DirectX 11 to 12
I called them and they refused to listen to me.
Very poor caliper of people in charge there.
Shame as the Trackball is a very good alternative to both the mouse and a joystick.
If they would update the driver then the trackball maybe a popular way to play games
The only way you can get it to work is to plugin another mouse
It will then work with all games
Kensington K72227 mouse
The mouse is too old and Kensington's website no longer supports it. Time to buy a different brand.
