20 Most Recent
Optimus STA-3500 Receiver Questions & Answers
Power to Amp but no lights and does not switch on
(1)When the unit is switched on the relay clicks in,but no sign of life, and then five seconds later the second relay clicks on/off don't know which. This symptom is DC outputted to speaker terminals. Check any DC at power amp stage output.(2)Must have blown up.
Positive. If Caps blew, your amp shutted itself down within 5 seconds due to + & - power supply creating an unbalanced +B & - B voltage not allowing your amp to turn on.
The volume is barely audible even with it turned
Maybe you have it muted or a Tape Monitor engaged??? Never troubleshoot anything at high volume. If you can't hear it at medium it's effectively noth there. A flip of a misplaced switch would possibly blow your speakers.
My fuse blew what kind is it to replace
Its probably a GMA fuse. Its value should be on the circuit board and on the old fuse. You can get replacements at Radio Shack or your local hardware store. Just make sure it is NOT a slow blow fuse. in most cases the fuse opens due to a problem with the receiver either in the power supply or more likely in the output circuit.
A slow-blow fuse takes a couple of seconds to open and in that time more damage will be done.
How to hook Optimus stav 3770 to tv
well mixing old AVR with newer TV (non told) or the reverse
does that,!
early AVR (mines packed in box attic) has no digital ports
only has RCA analog and no hdmi ports. (retired it ,just like me)
see there, that is progress. (1/2 joking)
just looked at 3770 is all analog a sea of white/red/yellow RCA jacks on the rear.. OLD tech.
no TV told but the the best TVs like LG and SAMSUNGS have both.
analog and HDMI digital jacks.
mine does. LG55xxxxxx
there are only 3 choices
new AVR, (best choice with a future)
buy older TV (hah)
buy LG with both on the rear.
se this?
D = digital
A = analog RCA pin jack inputs. video and audio too.
a far better TV has both not just HDMI.
Optimus stereo wont power up
- Verify the Unit Isn't in Protect Mode.
- Check the Fuses.
- Check the Pigtail Connector.
- Check for Power at the Head Unit.
- Check for Ground at the Head Unit.
- Bench Test the Head Unit and Replace if Needed.
