20 Most Recent
Samsung B2230 LCD Monitor Questions & Answers
Nothing happens when the power
make sure the power cable is inserted properly. try to unplug it and put it back again. if it doesn't work, try with a different cable, use your friend's cable with your monitor to check it out. if it works, then the problem is with the cable, if it still doesn't work, reply to this message please.
Resolution issues with samsung b2230
did you installed your graphics driver if not install it first and you can change your resolution may be your system don't have that capacity you have to buy a graphics card that will fit to your system config and instal drivers it will work. hope that it will help you thanks
When I was attaching the screen to a VESA arm, one
As it appears it seems that the back of the unit is held together by clamps. I wouldn't advise you to go ahead with the dis-assembly because you risk breaking the clamps. But if you must do it proceed with caution. Start prying open from the bottom screws toward the top of the unit. Use a plastic wedge to help the prying. It really comes down to finesse and experience. If you don't feel confident doing it don't do it as you might break it irreparable.
The mount should be usable even mounted in 3 points.On the other hand the loose nut could cause some damage short circuiting the board. \Good luckVlad
I have no sound on my new monitor
Hello John Kath624,
The Samsung B2230 LCD Monitor does not seem to have any speakers.
At Samsungs website the specifications state that there are no speakers:
linkSincerly,
Tim Jansen
My New Samsung B2230 LCD
Turn down the brightness of your monitor. There are touch sensitive buttons beneath the Samsung logo that will adjust things accordingly.
How do I find the instruction manual with codes for my Samsung 32" curved screen monitor ?
Manufacturer's Website: Go to the manufacturer's website (visit the official Samsung website in this case). Click on the support section, search your monitor model by product name or model number, and download your monitor model for the user manual. User manuals usually list codes and other relevant information.
User Manuals Online: Many people post user manuals online for all types of electronic devices and peripherals. You can search for your monitor and look for the user manual at sites such as ManualsLib, ManualsOnline, or Retrevo. Most of these sites will catalog user manuals for a wide variety of devices posted online by users and are normally free to access.
Physical User Manual: If you still have the original box or packaging with your monitor, there might be a copy of the user's manual in that box or enclosed. It might be in an actual printed booklet or perhaps just some links to online resources. Check under a section entitled 'Remote Control Codes' or 'Setup Instructions'.
Contact Samsung Support: If no luck finding it to download or to help you, there is contact support available, they should know where that information is, and be able to send it to you or refer you.
With these, you should be able to find the user manual for your Samsung 32" curved screen display and enter those codes.
4/13/2024 10:32:28 AM •
Samsung...
Answered
on Apr 13, 2024
