20 Most Recent Microsoft Office Professional 2010 Questions & Answers
2answers
Microsoft 2010 error occurs while importing pictures, graphic file
Reinstall MS Office and see if it helps.
10/8/2022 4:04:29 AM • Microsoft Office... • Answered on Oct 08, 2022
Setup cannot find proplus.ww owow64ww.cab
How to fix - Setup cannot find ProPlus.WW\ProPsWW2.cab
When you receive the error "Setup cannot find ProPlus.WW\ProPsWW2.cab" it might mean the MD5 checksum the install was expecting and the one on the actual file do not match. Here's how I fixed the issue. First let me explain in simple terms what the MD5 is. MD5 is an algorithm that is used to verify data integrity. If anything in the file changes the MD5 will also change so it's a way for the program to check the integrity of the file. The MD5 file is kept in the setup file of the proplus.ww folder. Open it with notepad and find the section that looks similar to the following **the numbers after "MD5 =" is what you need to be concerned with. Also remember that your numbers may differ. ** <LocalCache DownloadCode="{90140000-0011-0000-0000-0000000FF1CE}" SkuComponentDirectory="ProPlus.WW"> <File Id="Office64WW.xml" MD5="899A7D743D01852EBD036B465D1EF181" Size="4685" RelativeCachePath="Office64WW.xml" RelativeSourcePath="Office64WW.xml"/> <File Id="Office64WW.msi" MD5="43B44C38BE513D9589ECAC7129DDC7C3" Size="3025408" RelativeCachePath="Office64WW.msi" RelativeSourcePath="Office64WW.msi"/> <File Id="OWOW64WW.cab" MD5="E1E97F01F4292B89953204557A043C7D" Size="23865400" RelativeCachePath="OWOW64WW.cab" RelativeSourcePath="OWOW64WW.cab"/> <File Id="ProPlusWW.xml" MD5="146CA2B8E1559F81E8DF6A3AED949E2A" Size="17252" RelativeCachePath="ProPlusWW.xml" RelativeSourcePath="ProPlusWW.xml"/> <File Id="ProPlusWW.msi" MD5="F7DCCD578605F72AEEED775C9EB40AB8" Size="24809472" RelativeCachePath="ProPlusWW.msi" RelativeSourcePath="ProPlusWW.msi"/> <File Id="ProPsWW.cab" MD5="3EA469E81A6064AE4BEFE4A9ACF36A9D" Size="149278843" RelativeCachePath="ProPsWW.cab" RelativeSourcePath="ProPsWW.cab"/> <File Id="ProPsWW2.cab" MD5="86BEB0B6A2E76E95E580615185C06B04" Size="197934115" RelativeCachePath="ProPsWW2.cab" RelativeSourcePath="ProPsWW2.cab"/> <File Id="setup.exe" MD5="4D92F518527353C0DB88A70FDDCFD390" Size="1100664" RelativeCachePath="setup.exe" RelativeSourcePath="..\setup.exe"/> <File Id="osetup.dll" MD5="FCC38158C5D62A39E1BA79A29D532240" Size="5789544" RelativeCachePath="osetup.dll" RelativeSourcePath="osetup.dll"/> <File Id="ose.exe" MD5="9D10F99A6712E28F8ACD5641E3A7EA6B" Size="149352" RelativeCachePath="ose.exe" RelativeSourcePath="ose.exe"/> <File Id="pkeyconfig-office.xrm-ms" MD5="3DCFF1DCDEB1B837EC8F13351C8A92AC" Size="715834" RelativeCachePath="pkeyconfig-office.xrm-ms" RelativeSourcePath="pkeyconfig-office.xrm-ms"/> <File Id="PidGenX.dll" MD5="7F120AAD20ECAE1EA421083F26611519" Size="1248016" RelativeCachePath="PidGenX.dll" RelativeSourcePath="PidGenX.dll"/> <File Id="Setup.xml" MD5="" Size="" RelativeCachePath="Setup.xml" RelativeSourcePath="Setup.xml"/> </LocalCache> Next you will need to download and install an MD5 checker. I'll leave the process of how to use the MD5 to you to learn but it's pretty simple. Next run the MD5 checker on the file/s that produce the errors during install. *there may be more than one* Now there are 2 ways to work around this - If the MD5 on the checker did not match the MD5 in the file it probably means the file is corrupted so your best bet is to download the software again or get another disk. Another less recommended way is to copy/paste the MD5 from the checker into the file (remember to make a backup of your setup file before) then save it and run the install again. This fools the installation process into verifying that your installation files are all OK. Good luck!!
1/29/2019 3:49:01 PM • Microsoft Office... • Answered on Jan 29, 2019
10answers
I need a product key
Office 2016 Product Key http://www.Windows10KeyShop.com/ Go to http://www.Windows10KeyShop.com/ . I must thank them! My 2016 for Mac just activated and worked well, they do provide the warmest customer service i ever met. because of employees like http://www.Windows10KeyShop.com/ , i will refer everyone to this site. http://www.Windows10KeyShop.com/
5/29/2018 12:02:11 AM • Microsoft Office... • Answered on May 29, 2018
2answers
ACTIVATION MICROSOFT OFFICE 2010 PROFESSIONAL
You can activate it online at microsoft.com
11/24/2016 2:50:27 AM • Microsoft Office... • Answered on Nov 24, 2016
Size of the excel file increased from 721 KB to 50MB
Many businesses use Excel to track their data and expenses. However, you can run into problems when files grow too big. Try reducing the size of your Excel files in different ways to eliminate your storage problems. Remove unnecessary graphics and fonts from the Excel file. Simple report data doesn't need a lot of excess formatting to make it attractive. If you need to keep different fonts in your file, reduce some of the font sizes you originally used. Reduce the number of pivot tables you allow in your data analysis. Run your pivot table wizard when dealing with involved calculations. When given options to format the file, choose those that allow the data to refresh instead of adding a new table. Input your data, close the file and save as an Excel (XLS format) file and as an HTML (XML format) file. To do this, choose "XML Data" in the "Save as type" drop down box. Change the name of your document as well, so you can tell the difference between the two files. Open the XML file and save it back into the regular XLS file to create a smaller file than the original. Again, rename this file, as well as changing its type. This act removes odd programming left from past calculations since the last "save." Check into file compression software such as OzGrid. These products exist because you cannot open a file once it gets too big. Compress the XLS data by compelling the program to recalculate the cells used for your file. Excel File Size Reduce Software 7.0 http://www.newfreedownloads.com/Business/Spreadsheets/Excel-File-Size-Reduce-Software.html http://www.ozgrid.com/or Microsoft Excel files can contain thousands of cells filled with data. When you combine this information with graphics, such as charts and graphs, as well as ever-expanding links to other worksheets, you can end up with an enormous file that takes up precious system space and slows Excel down. While there are many software programs available that promise to shrink Excel files, there are many ways to reduce the bulk without downloading a new application. 1. Click on any cell in the Excel file you want to reduce. Open the "Go To" dialog box in Excel 2007 by clicking the "Find" drop-down arrow on the Home tab of the ribbon and selecting "Go To." In Excel 2003 or earlier, go to the "Edit" menu and select "Go To." You can also use the keyboard shortcut "Ctrl+G" in any version of Excel. 2. Click the "Special" button on the "Go To" dialog box. Select "Blanks" and click "OK." Click the "Clear" drop-down in the "Editing" group in Excel 2007 and select "Clear All." In Excel 2003 or earlier, go to the "Edit" menu, point to "Clear" and select "All." This will clear any blank cells to help reduce the file size. 3. Go to the very last cell containing data in the Excel file. Select the entire row beneath this cell by clicking the number to the left of it. Hold "Ctrl+Shift" and then press the down arrow key to select all of the cells beneath this point. 4. Click the "Clear" drop-down in the "Editing" group in Excel 2007 and select "Clear All." In Excel 2003 or earlier, go to the "Edit" menu, point to "Clear" and select "All." Select the column to the right of the last cell. Hold "Ctrl+Shift" and then press the right arrow key. Again, select "Clear All." 5. Repeat Steps 1 through 5 for any other Excel files that are linked to the workbook you are trying to reduce. Save the files and then check the new file size by clicking the "Office Button" in Excel 2007. Point to "Prepare" and then click on "Properties." In Excel 2003 or earlier, go to the "File" menu and select "Properties." The file size will be listed on the "General" tab. http://www.ozgrid.com/Excel/ExcelProblems.htm
8/20/2016 9:04:01 AM • Microsoft Office... • Answered on Aug 20, 2016
5answers
Lost product key for ms office 2010
Hi, if you lost your Office 2010 product key, you can try to use the SmartKey Product Key Recovery because it is really helpful, at least works for me. You can read this article about how to find Office 2010 product key - http://www.recoverlostpassword.com/article/office-2010-product-key.html
6/2/2016 8:48:19 AM • Microsoft Office... • Answered on Jun 02, 2016
2answers
Microsoft office 2010 prodect key
The product key comes with the CD. It is generally at the back of the cover. If you have down loaded the programme online from Microsoft site than the key will be provided by the site. Remember the product is not free and you will only get once you have made the payment. If you have downloaded it under the trial scheme then the key will be provided to you after making the necessary payment.
5/26/2016 5:15:29 AM • Microsoft Office... • Answered on May 26, 2016
Product key for ms office 2010 -X12-30307
https://support.microsoft.com/en-us/kb/836178
5/24/2016 1:41:38 AM • Microsoft Office... • Answered on May 24, 2016
4answers
What is Office 2010 Professional Product Key?
Office Professional 2010 76XCJ-YMH2W-YQQV6-X76X-QK3K7 Office Professional 2010 XJ2G2-TDQ49-3MW8D-F4FCT-KPTT6 Office Professional 2010 BGCKH-CRYRT-49VQ7-YMCG3-BRBP7Office Professional 2010 W4D2C-3YK88-KMYP2-2QTXY-28CCY Office Professional 2010 9GVVR-X6VJT-WDDXD-YB4M2-RQ7CV Office Professional 2010 2K79J-DVFWG-MJT2Q-BX82R-T9PDVOffice Professional 2010 6QFDX-PYH2G-PPYFD-C7RJM-BBKQ8Office Professional 2010 BDD3G-XM7FB-BD2HM-YK63V-VQFDKOffice Professional 2010 YHDT7-WPQX9-BCYDM-6VJ9K-KRDMWOffice Professional 2010 6TX3V-WRDJ6-JC34X-BDDPV-6F3PBOffice Professional 2010 KGTM8-XGW8X-D3PWD-8HPHW-4JJ42Office Professional 2010 TTK27-44W3B-PVC8K-XJQW8-KJMVGOffice Professional 2010 2VQRW-HFRGP-733PM-Y737F-K7BBBOffice Professional 2010 H2VKD-G9CBT-D2JXH-JFTT6-C22WFOffice Professional 2010 PYVW4-KHTM7-6WPTF-VVDHV-826D8Office Professional 2010 YDCTD-DKK23-4C3P9-CP8RB-9VVBVOffice Professional 2010 CXQWG-BJWPX-VWWCJ-CJJGV-29G2TOffice Professional 2010 TVFJ7-76TR7-HHCKT-QQFJR-8KTTD
5/24/2016 1:40:00 AM • Microsoft Office... • Answered on May 24, 2016
2answers
I need ms visio 2010 key
I'm sorry but this is not a warez site...We can't give out activation keys or access codes.
4/18/2016 6:07:39 AM • Microsoft Office... • Answered on Apr 18, 2016
Activation visio 2010
If you want permanent activation use this microsoft office 2010 Activator, try to search @@@windows 8.1 key sale@@@ on bing
4/15/2016 6:02:00 AM • Microsoft Office... • Answered on Apr 15, 2016
3answers
How to download free trial
Here is a link:
http://office.microsoft.com/en-us/professional/
There is a link to try it free below the picture. You will have to create an account before downloading.
Thanks for using Fixya.
3/3/2016 3:28:52 AM • Microsoft Office... • Answered on Mar 03, 2016
2answers
Plg send me ms office
Install Microsoft Office 2010 professional plus with this serial:BBXQ7-X97RP-GDFXM-FY784-F6CC4And then you download full version activator from this link. www.ziddu.com/download/14220254/MicrosoftOffice2010professionalplusActivator.rar.html...
3/3/2016 3:25:50 AM • Microsoft Office... • Answered on Mar 03, 2016
2answers
Microsoft 2010 repair without cd
Try to repair your MS Office 2010 from the control panel. To do this, follow below steps:
  • Click Start > Control Panel > Programs > Programs and Features.
  • Click on Office program to repair, and then click Change.
  • Click Repair > Continue.
Note: You may need to restart your system after repair process.
2/1/2016 7:50:11 AM • Microsoft Office... • Answered on Feb 01, 2016
2answers
Excel in Office Professional 2010 has stopped sorting
Reinstall the software for the better.
2/1/2016 7:49:29 AM • Microsoft Office... • Answered on Feb 01, 2016
2answers
Product key for ms.office 2007
If you have a legal copy of MS Office then The Product key is on a label stuck onto the back of the box, or inside on the leaflet, or on the back of the sleeve for the disk(s) If the product key is lost, contact Microsoft support as they may be able to help. If it has been registered with Microsoft already they can usually recover your key. Contact Support at http://support.microsoft.com/?ln=en-gb
2/1/2016 7:49:03 AM • Microsoft Office... • Answered on Feb 01, 2016
2answers
Product key for office 2010
If you purchased an authorized version retail and the product key is not in the box, return it to the person you purchased it from. If you got it with a computer, sometimes product keys can be pasted on your computer somewhere on a sticker. Or attached to a CD along with the restore disks. It is also possible that the "restore" option is a hidden segment on the hard drive triggered by a specific keypress during startup.
2/1/2016 7:48:23 AM • Microsoft Office... • Answered on Feb 01, 2016
2answers
I need to get the activation/ serial code
you would have to buy it to get actication code. Although there are other free office software out there.
2/1/2016 7:47:53 AM • Microsoft Office... • Answered on Feb 01, 2016
2answers
Ms office 2010 is left with one day to expire, how do I activate again
If you have not bought a lid key you ned to buy one. Amazon oc world etc. however, 2010 is no longer in general release so you may ned to look for old stock. Failing that if you are running windows 7 you could buy office /word 2013
8/20/2015 3:32:31 AM • Microsoft Office... • Answered on Aug 20, 2015
Computers & Internet Logo
162 questions posted
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Office Microsoft
  • Office Microsoft
Most Popular Question
need product key
  • Computers & Internet
