20 Most Recent
Google Toolbar for Internet Explorer Questions & Answers
Google is gone
Ask.com is a pain. You need to go to your browser settings>preferences and set google as the default search engine again. Also check under your list of installed programs (under control panel) for anything with the word "Ask" and get rid of it!
[email protected]
Point your web browser at
http://www.gmail.com
If another account comes up, sign out of it by clicking the avatar in the upper-right then clicking "Sign out."
If you then still can't sign in to your account, click the "Can't access your account?" link on the sign-in page.
Websites sometimes look weird on mobile is there
This is due to the fact that the websites that look wired are not compatible or not designed for mobile browsers. Regrets to tell you that you can not do much about it as this depend upon the browser that how it render the webpage to be displayed. Since you are able to view other websites properly that why I dont think so that there is anything wrong with your browser's configurations.
Cant open internet explorer
you will need to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk
Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals
look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled
to create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
click on the tools at the bottom of the drop down list will be internet options or
click start control panel internet options you will see a home page box To Create Page Tabs type
each adress on its own line (type in google.com) or your preferred home page and browser
below that will be change search defaults click on settings you will see all search providers you
have if dont need any of them you can disable or remove them
click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details
or type in your default gateway adress into your internet search should read something like 10.0.0.138 to get an inertnet connection
hope it helps
Restore last web sight
Google toolbar never restores the last website....
you need a different browser for this...
Mozilla Firefox is the best suggestion...:)
Is it legal to use Chrome browser without google sign in or sync sign in?
in what country , is there a CHROME , law.
all browsers, made have settings page, that you can tell it , do no store my credentials
read the manual on Chrome.
if asking a legal question post to legal forum , and tell the country first. or you will not get the truth
if only PC question, them learn to use Chrome settings
I keep all that turned off and use app like LASTPASS to control all that. (or the like kind,) NordPASS (
How do I fix my Hisense LED LCD Google Android model 55H6D tv that froze up on the download screen?
Power cycle your TV: Turn off the TV using the remote control, unplug the power cord from the power outlet, wait for at least 5 minutes, plug the power cord back into the power source, and then turn on the TV .
Check your internet connection: If your TV is freezing when downloading, it could be due to a poor internet connection. You can check your internet speed by visiting speedtest.net on your TV's browser. If you have a slow internet speed, try disconnecting other devices connected to the Wi-Fi router while watching shows on Prime Video .
Factory reset your TV: If the above steps don't work, you can try factory resetting your TV. To do this, turn on your Hisense TV and navigate to Menu by pressing the "MENU" button. Proceed by selecting "Support" with the "Select" or "OK" button. Start the self-diagnosis by pressing "OK". Choose the "Reset" option now.
Laptop Open Homepage Set direction
Hi, I think maybe you have set the Chrome homepage to the website that you are visiting too much. Please go to the 3 dot and then go to the setting then find the search engine and after you can check chrome homepage.
Scan to Google Drive, An Internal error occurred. (255)
I'm sorry to hear that you're experiencing issues with scanning and saving documents to your Google Drive folder. The error message you mentioned, "An Internal error occurred (255)," typically indicates a problem with the scanning software or the connection between your scanner and Google Drive.
Here are a few steps you can try to troubleshoot and resolve the issue:
1. Check your internet connection: Ensure that you have a stable and reliable internet connection. A weak or intermittent connection can cause errors during the upload process. You can try restarting your modem/router or connecting to a different network to see if that resolves the problem.
2. Clear browser cache and cookies: If you're accessing Google Drive through a web browser, clear your browser's cache and cookies. Sometimes, outdated or corrupted cache files can cause issues with file uploads. After clearing the cache, restart your browser and try scanning and uploading the document again.
3. Update your scanner drivers: Visit the website of your scanner manufacturer and check if there are any updated drivers or software available for your scanner model. Outdated or incompatible drivers can cause scanning issues. Install any available updates and restart your computer before attempting to scan again.
4. Try an alternative scanning method: If you're using specific scanning software, try using a different scanning application or method to see if the issue persists. For example, you can use the built-in scanning functionality provided by your operating system or try a different scanning application altogether.
5. Contact scanner and Google Drive support: If none of the above steps resolve the issue, it's recommended to reach out to the support teams of both your scanner manufacturer and Google Drive. They can provide you with specific troubleshooting steps and assistance tailored to your setup.
Remember to provide them with detailed information about the error message, steps you've already taken, and any specific error codes or messages you encounter during the scanning process. This will help them diagnose and resolve the issue more effectively.
I hope these suggestions help resolve the problem you're experiencing and that you're able to scan and save your documents successfully.
