20 Most Recent Samsung S3500i Cell Phone Questions & Answers
S3500i hard reset
first shut down it then keep holding #,3 and the green button for 3 seconds then while pressing on them power on the phone
6/5/2013 12:48:01 PM • Samsung S3500i... • Answered on Jun 05, 2013
My samsung s3500 speaker is ok but not working
try to do soft reset by *2767*2878# or by settings maybe it is a minor software error.
9/5/2012 8:48:22 PM • Samsung S3500i... • Answered on Sep 05, 2012
2answers
Hi first I would like to thank you inadvance your
I assume that you can at least see the display like texts or images on the screen even if it's dark. There four things which can cause this, first the display cable (flex cable), second the display connectors on the display or on the board of the mobile/phone,third is display ic and the fourth is the display itself.
To troubleshoot this, it's a must to open apart the set, you'll need appropriate screw drivers and spares like display and flex cable.
Open the case, disconnect the terminals of the display flex cable from both the display and from the board, do some cleaning with alcohol/spirit/ipa solution with a soft brush, and again reconnect them after it's dried. If this isn't successful, go to next step.
Next replace another cable (display) and check if you can see the light on the screen or not. Again there's no light? Next step...
Connect the other display (should be a working display of the same model and type). If the problem goes, then your solution is replacing the display. If not the display ic which only professionals and trained technicians can handle.
Hope this helps.
Good luck.
Thanks for using FixYa.
9/12/2011 2:07:22 PM • Samsung S3500i... • Answered on Sep 12, 2011
0answers
M using s3500i n not
Yo! I will have to direct you to a website where you can download anything for your phone. please follow the links below..
www.download.com
getjar.com
waptrick.com
4shared.com
7/31/2011 8:24:30 AM • Samsung S3500i... • Answered on Jul 31, 2011
0answers
0answers
Using samsung s3500 mobile..when i
Probably, when a memory card is damage or corrupted,the phone fails to read the card and its content. The games and application installed on your memory card might be the problem thats why you phone restart.
Here's the Solution :
* Reset your phone by typing this code on your homescreen *2767*3855# ,this method will restore settings into default as well as easing all contents including contacts,messages etc. So before doing this thing,be sure to back up all important data first.
* Format your memory card on pc or in your phone and try to load another games and applications.
Remember that all file you download should be placed in memory card and not on the phone memory.
Hope this solution helps...thanks
6/12/2011 5:16:23 PM • Samsung S3500i... • Answered on Jun 12, 2011
My kids have put password
Type this code below on main screen after you remove the sim card:
*2767*3855#
6/4/2011 10:42:32 AM • Samsung S3500i... • Answered on Jun 04, 2011
Hi........ in ma samsung cell,when i
This CODE below is for erase the old security code and reset the all mobile settings to its original settings:
*2767*3855#
And about the applications installation on your mobile...use SAMSUNG PC STUDIO program
from www.samsungmobile.com
and use it to connect your mobile to your PC ,and install applications like :dictionary and other applications.
6/3/2011 7:06:58 PM • Samsung S3500i... • Answered on Jun 03, 2011
I want samsung default reset pin for reset
Hello and Welcome to FixYa!
If you haven't changed
reset pin code before then Default reset pin code for samsung is 00000000 (eight zero's)
I hope it works.
For further assistance i am here to help.
Thank you for using FixYa!
Concerned: Angel Bird
5/14/2011 9:33:15 AM • Samsung S3500i... • Answered on May 14, 2011
Unlocking code of s3500i game of samsung
2/21/2011 11:01:11 PM • Samsung S3500i... • Answered on Feb 21, 2011
How can i download themes
you can download it here-->http://www.freedownloadmanager.org/downloads/s3500i-themes-515638.html
OR
you can download the pc suit for your mobile and you can directly copy the themes from you pc to mobile. Download pc suit here-->http://ptf.com/pc/pc+suite+for+samsung+gt+s3500i+free+download/
thanks for rating good luck
2/16/2011 3:17:01 PM • Samsung S3500i... • Answered on Feb 16, 2011
What is the default phone code of Samsung S3500i
You can get the unlock code through online..........i will suggest the website unlock-zone.com which is doing good service .....you can approach this website.
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
2/11/2011 11:49:58 AM • Samsung S3500i... • Answered on Feb 11, 2011
I cant see any font
Hi
Switch off the your mobile and switch on again take the battery out also and again reinsert it.
besides please make sure that your battery is fully charged.
Regards
Vipin
1/25/2011 6:35:18 PM • Samsung S3500i... • Answered on Jan 25, 2011
Samsung metro s3500i pc connecter
Hello, what is wrong with the PC connector? Is it broken, missing, do you need a cable?
1/12/2011 8:50:19 PM • Samsung S3500i... • Answered on Jan 12, 2011
The phone was reset, accidentally lost all
Sorry you cannot retrieve the lost contents.No option is there to doing that.
Thank You
1/11/2011 3:50:12 AM • Samsung S3500i... • Answered on Jan 11, 2011
How will lock my Phone
if you want to automatic key lock , you can find the option under " menu>settings>phone settings>automatic key lock"
for security key lock "menu>settings>phone settings>security key guard"
12/29/2010 9:54:45 AM • Samsung S3500i... • Answered on Dec 29, 2010
Samsung S3500i Cell Phone Logo
56 questions posted
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Samsung Cell Phones
  • Samsung Cell Phones
Most Popular Question
samsung s3500 speaker ok but not working
  • Cell Phones
