20 Most Recent Mitsubishi VS-80803 TV Questions & Answers
Powers itself off after 1 hr of use
Has the timing control board been changed?...or is it part of the panel on your set?
11/24/2017 7:59:20 PM • Mitsubishi... • Answered on Nov 24, 2017
I need a cable for High Def from my cable HDMI
Get a good quality 28G cable, and check what length you need to reach. eBay has many listings, and any consumer electronics store will have them. Be wary of overpriced cables though. EBay is a good yardstick.
10/25/2013 12:27:54 AM • Mitsubishi... • Answered on Oct 25, 2013
manual
Do you need a converter
Are you asking if you need a converter box to receive your over the air broadcast digital/hd channels? If so the answer is yes. If you have a yellow, red, white composite input it can go there or it can be connected to the rf input.
8/13/2011 2:16:40 AM • Mitsubishi... • Answered on Aug 13, 2011
My model number is vs80803
What exactly is the problem with the tv?
8/7/2011 2:15:49 AM • Mitsubishi... • Answered on Aug 07, 2011
tip
hello.i have this TV i don't have remote control and me TV is american system and need me converted to EU confirm...
Hey I have a mitsubishi
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
6/6/2010 4:48:38 AM • Mitsubishi... • Answered on Jun 06, 2010
Bowing convergence lines
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
3/25/2010 5:02:01 AM • Mitsubishi... • Answered on Mar 25, 2010
Leaking oil
TV's do not have oil, but something very close. It is probably one of the CRT's leaking coolant. You need to find out which one or replace all three.
12/30/2009 10:34:35 PM • Mitsubishi... • Answered on Dec 30, 2009
No picture
Are you sure its not a VS60603 ? VS80803 is not a valid model number for mitsubishi. If it is a VS60603 you can get a manual at the following link and they will contact you asking if you would like it emailed instantly. Its 10.99 for the Manual. Heres the link
they have quite a few Mitsubishi as well as other models and they offer free support with the manual.
http://servicemanuals.vstore.ca/
8/26/2008 1:07:31 AM • Mitsubishi... • Answered on Aug 26, 2008
How to set up hd on this tv
Hi Brien,
You can hook-up your HDTV via the BNC inputs with the right equipment below.
Here is the link to a website that sells video transcoders for projectors and projection televisions. In addition, the link will take you to one particular transcoder that will work for your application.
http://www.curtpalme.com/RTC2200.shtm If you use this transcoder you will have to find a VGA to 5-BNC breakout cable to connect the output of the transcoder to your TV HDTV RGBHV inputs. The extra VGA input on this transcoder will not be used for your application. They sell another product that comes with the cable you need, but I did not see it listed separately. That product is their HDFury Basic Kit at the link below.
http://www.curtpalme.com/HDFury.shtm
Regards,
MyTvGuy
1/15/2008 4:22:44 PM • Mitsubishi... • Answered on Jan 15, 2008
Mitsubishi DLP 73 inch TV WD-73738 is blinking 6 red and 1 yellow, replaced the color wheel, and still having the same problem?
The lamp is not enabled possibly due to the colour wheel motor not turning. Any broken glass jamming it? Or the lamp ballast has failed due to an old/worn lamp.
4/10/2024 7:05:08 AM • Mitsubishi... • Answered on Apr 10, 2024
2answers
I have a mitsubishi dlp tv model wd 60738 and when i turn it on the power button blinks for a second and then it stops but no picture and after while turns off
Most likely you need to replace the projection bulb. You can find them online. DLP sets are famous - or infamous - for burning out the bulbs/lamps.
3/11/2024 7:56:47 PM • Mitsubishi... • Answered on Mar 11, 2024
Mitsubishi VCR HS-U580 guide rollers not moving forward all the way. Cassette would not load. Also noticed drum not spinning when powered on
Your Mitsubishi VCR HS-U580 looks to have a problem with the information rollers and drum. Here are some things to check: Look for something blocking the VCR or cassette compartment that would possibly be stopping the guide rollers. Check the belt that drives the VCR mechanism. If it is loose or broken, you may also need to substitute it. Clean the video heads using a head-cleaning cassette to make certain they're not dirty. See if the drum motor is working. If it is not spinning, there may be an issue with the motor. If the trouble persists, it's an exact idea to get assistance from a professional technician or contact Mitsubishi's purchaser support for advice. Be cautious when dealing with electronic devices, and if you are not certain what to do, it's great to get assistance from an expert.
2/20/2024 5:32:32 PM • Mitsubishi... • Answered on Feb 20, 2024
Where could I download a copy of a service manual for mitsubishi hs-u580 vcr?
i think finding a downloadable service manual for your Mitsubishi HS-U580 VCR might take some searching, but here are a few options: Check the official Mitsubishi website's support section. They might offer downloadable manuals for older models.Many online appliance parts stores like RepairClinic or AppliancePartsPros stock service manuals for various brands and models. Search for your specific VCR model to see if they have it available.Websites like ManualsLib or iFixit sometimes host user-uploaded service manuals. While the availability and quality can vary, it's worth checking. If online options fail, consider purchasing a physical copy of the service manual from online marketplaces like eBay or Amazon. Remember, some websites might charge a fee for downloading manuals. Always be cautious of suspicious websites and download from reputable sources.
2/12/2024 8:58:07 PM • Mitsubishi... • Answered on Feb 12, 2024
Looking for power cord replacement for Mitsubishi model #LT-55164
You can purchase a replacement power cord for your Mitsubishi model #LT-55164 from TVserviceParts.com. The part number for the power cord is 246C638010 and it costs $18.40.
12/30/2023 8:16:17 PM • Mitsubishi... • Answered on Dec 30, 2023
I own a Mitsubishi 1080 1EEE 1394 television. Yesterday, we had a planned power outage in our area. When the power was restored, the only picture I can get is flipping horizontal lines?
Hoping you did not have electric overload that damaged the power supply, try unplugging the set and push the button On until no lights indicate anything. Then wait about an hour so the capacitors would empty themselves further. Next plug it back in and see if this worked. It is never wrong to push the edges a little in finding if the cables that go around the screen have a problem at that point. When one opens the TV (off power and unplugged) these flat cables should be checked for corrosion and right position in connectors. Corrosion is caused by little moist only, combined with the electricity. Then see if capacitors from the power supply, or any at all, have expanded tops. Those are the larger and smaller towers with metal on top that is divided in three parts. New ones alike can then be ordered but replacing requires basic skills. Further examples can be found on YouTube. Capacitors are common to fail early. Those larger ones have dangerous high voltage and can hold their charge for long span of time. it is not uncommon for devices like this to fail after being off.
10/16/2023 2:11:33 AM • Mitsubishi... • Answered on Oct 16, 2023
Mitsubishi WS-65511 Projection Television won't turn on.
Question edited for clarity. 'make model (what it is)'. Question moved from Cell Phones category. 12 ----------- indicates no error 21 ------------- X-Ray Protect circuit 22 ------------ Short Protect circuit 23 ------------- Horizontal Deflection failure 24 ------------- Vertical Deflection failure https://www.google.com/search?q=Mitsubishi+WS-65511+code+22 Antique technology ..
9/16/2023 5:38:18 PM • Mitsubishi... • Answered on Sep 16, 2023
Mitsubishi VS-80803 TV Logo
Popular Tags
18 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
set up hd tv
  • Televison & Video
