20 Most Recent Recoton Advent Advent AW810 Main / Stereo Speaker Questions & Answers
Recoton CD22A Multi-Voltage Car Adapter... Can it be changed to be used in a home..i.e. standard 110 plug?
At most large chain "Wally-World" type stores there are 110-120vac to 12vdc wall wort type of adapters. These adapters are simply plugged into a typical home outlet (110-120vac) while the 12vdc male end of the multi voltage device plugs directly into the adapter. (Compare output current specs of adapter to be sure it's adequate for devices you plan to power up)
2/17/2024 8:01:08 AM • Recoton Advent... • Answered on Feb 17, 2024
Popping sound in the Rocoton Advent Wireless speaker
Double check your connections at the transmitter. Swap inputs to see if the popping moves to the other speaker. Popping usually means blown, however......
12/13/2009 8:05:33 PM • Recoton Advent... • Answered on Dec 13, 2009
Advent AW810 Wireless Speakers
Turn your tv speakers off via setup.
You can't run both tv & audio out on any tv I have seen.
12/8/2008 9:23:05 PM • Recoton Advent... • Answered on Dec 08, 2008
Need new AC adapter for the Recoton Advent AW810
Check at RadioShack
10/17/2007 7:58:34 AM • Recoton Advent... • Answered on Oct 17, 2007
0answers
Almost no volumn on a
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it if his does not fix the problem click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps you if you dont have a motherboard disc you will have to download the drivers
8/26/2011 9:17:14 PM • Recoton Advent... • Answered on Aug 26, 2011
My latops speaers are not givig out sound
First check whether the audio volume is not muted, and turn the volume all the way up, if you didn't already try that.
Did you try playing the system sounds? Enable them from the Control Panel (double click the sound and audio devices icon from the Control Panel), if you didn't try them, or if they aren't enabled. Then, play one of the system sounds from the "Sounds and Audio Devices" (second tab, labeled sound).
Can you see a speaker icon in your system tray? If yes, double click it. Do you get the 'Master Volume' control or do you get a message that says something like you don't have audio enabled?
If you get such a message, then the audio drivers are missing or corrupted, or not properly installed.
If you can open the Windows Device Manager, open it and check whether the sound drivers are present and are functioning correctly.
(For opening it in Windows 7, open the Control Panel from the Start Menu. Click on the System and Security link. In the System and Security window, click on the Device Manager link located under the System heading.  (Another easier way is to click the Start button and type the following command in the search box: devmgmt.msc Then, hit the enter key.
In Device Manager, expand the 'Sound, video and game controllers' (click the plus sign next to it). See that the sound driver is listed. Double click the item in that list that contains the word "audio device" in its name. Does Device Manager say that the device is working properly?
Instead of manually searching for the drivers, or your old drivers CD (you probably don't even remember where you kept it), you can download this driver scanning tool from here: http://xpdrivers.com/index.cfm or directly from this link: http://xpdrivers.com/download/download.cfm
After you download it, double-click it to install it and follow the simple instructions and run this tool to scan your system. It will inform you and update the needed sound drivers.
Hope that helps,
Regards,
Raspal
For Windows XP Driver Files and How-to Resources, visit http://xpdrivers.com
Some FAQ about laptop sound and Windows 7: http://windows.microsoft.com/en-US/windows7/Sound-cards-frequently-asked-questions
3/20/2010 7:56:37 AM • Recoton Advent... • Answered on Mar 20, 2010
Vocalizer 3 output checked cables and swapped out. 1300 watt power adaptor lights up. sound indicator light is on but no sound. tried mono and stereo. power adaptor problem?
If the display is working, you have audio. Check your amplifier. 1300Watt adaptor ... This unit draws a very low power and that is not needed.
4/24/2024 7:18:55 AM • Audio Players &... • Answered Yesterday
How do I change to degree mode on my porpo YH-2000
  1. Power Off: Turn off the device.
  2. Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
  3. Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
  4. Power Off Again: Turn off the device once more.
  5. Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
  6. Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
4/20/2024 8:57:52 PM • Audio Players &... • Answered on Apr 20, 2024
Panasonic SA-PM250 CD stereo system. Tune dab radio sa pm250?
this model SA rather than SC seems to be a Middle East model. The SC version doesn't have DAB. https://www.google.com/search?q=panasonic+sa-pm250+instruction+manual ..
4/20/2024 5:59:04 PM • Audio Players &... • Answered on Apr 20, 2024
Setting time on fmdott085 V398
All questions need clear 'make model (what it is)' first 3 words. https://www.google.com/search?q=fmdott085+V398 ..
4/17/2024 4:54:26 PM • Audio Players &... • Answered on Apr 17, 2024
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS. Question moved from Cars and Trucks category. Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries. How long is the warranty on AfterShokz? While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase. Jan 11, 2019
How To File A Warranty Claim For Your SHOKZ Headphones
https://www.google.com/search?q=Openfit+Shokz+battery+replacement ..
4/16/2024 4:58:24 PM • Audio Players &... • Answered on Apr 16, 2024
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first. But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
4/16/2024 5:57:29 AM • Audio Players &... • Answered on Apr 16, 2024
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
4/10/2024 6:11:44 AM • Audio Players &... • Answered on Apr 10, 2024
Zenith Allegro console stylus
I have the same model with the 8 track player, original manual, and original receipt dated 1975.
4/9/2024 1:32:47 PM • Audio Players &... • Answered on Apr 09, 2024
VIBE SOUND USB Turntable Model VS-2001-USBT. Where can I download drivers and application for it please?
Probably nowhere as this is an Amazon / eBay special so made in China. You should be able to go to Windows Settings, - Hardware and tell Winderz to find a compatible driver. https://www.google.com/search?q=VIBE+SOUND+USB+Turntable+Model+VS-2001-USBT+drivers ..
3/31/2024 1:46:10 AM • Audio Players &... • Answered on Mar 31, 2024
I'm looking for a manual to my IQ VOICE ORGANIZER
Hi I have a manual (and an IQ Voice organizer that I'm trying to sell). I would happily send you a pdf file of the manual if you contact me. Robert
3/30/2024 1:52:26 PM • Audio Players &... • Answered on Mar 30, 2024
Recoton Advent Advent AW810 Main / Stereo Speaker Logo
Popular Tags
5 questions posted
Top Recoton Advent Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Recoton Advent Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Recoton Advent Audio Players & Recorders
Most Popular Question
popping sound in rocoton advent wireless
  • Audio Players & Recorders
