20 Most Recent Ariens Zoom 42 In 165 HP Briggs Stratton Zero Turn Riding Mower () Questions & Answers
My Ariens Zoom zero turn mower looses left steering after about 1/2 hour running?
Question edited for clarity. Question moved from Cars and Trucks. See if the videos help. It sounds like a steering pump issue, because of the 'growling' the same as a car. Steering fluid up to level? https://www.google.com/search?q=ariens+zoom+lose+steering+after+30+minutes ..
6/25/2022 3:19:28 PM • Ariens Zoom 42... • Answered on Jun 25, 2022
It will not go forward it is only 1 year old and yes it starts my husband past away and I don't know what I am doing wrong
After the engine starts you must put the mower into gear so that it moves. Look for the gear shift lever or whatever.
8/2/2015 2:04:54 PM • Ariens Zoom 42... • Answered on Aug 02, 2015
4answers
Battery will not hold a charge. i charge it or jump it off and it will be dead the next time I use it. I even bought a new batter and it was drained when I went to use it again
It sounds like it has a short on it or the alternator isn't giving a charge. check the wiring for breaks... charge the battery up and get a altmeter to test if when running the battery is getting a charge, hope this helps
4/4/2015 4:48:14 AM • Ariens Zoom 42... • Answered on Apr 04, 2015
2answers
Need instructions on how wires attach to solenoid
One large wire to one large stud, the other large wire to the other large stud, and the small wire to the little side screw.
11/26/2014 8:37:26 AM • Ariens Zoom 42... • Answered on Nov 26, 2014
Need to know how to change blades on 42in zoom z turn
To make it easy for repair, jack up lawn mower from the front, use jack stands to support the front frame, if you have a engine puller handy you can hook a chain to the front frame. There should be a 5/8 or 9/16 bolt or nut on lawnmower blade, need a impact driver to remove, do not remove with a wrench or hand tools or you risk of breaking the mandrels. Be sure to check the splines that hold the blade on place for ware and when installing them be sure you have a snug fit and hold the blade in the slot and insert nut or bolt back in place, if the blade is not in the slot you can strip the shaft and it will have to be replaced. It is good to put anti seize on the bolt or nut threads to make it easier to remove and install.
5/31/2014 3:01:35 PM • Ariens Zoom 42... • Answered on May 31, 2014
How do i change the blades on a 42in zoom z turn
raise the front of the mower to gain access to the underside where the blades are, using the right size wrench undo the bolt or bolts that hold the blades on and remove them from the mower, replace the blades and tighten the bolts to the required torque, lower the mower to the ground and take it for a test run.
5/22/2014 8:05:35 AM • Ariens Zoom 42... • Answered on May 22, 2014
0answers
0answers
Turn zero
sorry but i would talk to the shop about that.
12/29/2013 4:34:56 PM • Ariens Zoom 42... • Answered on Dec 29, 2013
BATTERY HAS FULL CHARGE WHEN I TRY TO START IT IT DOES NOT TURN OVER NO CLICKING NOTHING CAN SOMEONE HELP ME. ARIENS 1740
Check to see if the solenoid is getting power. On the solenoid there are 3 wires. Two big, one from the battery, the other going to the starter. The 3rd wire is what activates the solenoid. Using a test light or volt meter. See if its getting power on the small wire when you turn the key. If no power, ignition switch, safety switches or fuses. If you are getting power replace the solenoid. If you have 4 wires. Test the two smaller ones.
10/18/2012 8:25:27 PM • Ariens Zoom 42... • Answered on Oct 18, 2012
Governor runs wide open when srarted
spring must be broken that holds tension remove engine cover or look on side of carb and vain lever and see if there is a mouse nest in under the engine cover or if spring is broken dont let it rev you will blow a rod, sometimes the govenor comes apart in the engine you will need a small engine shopJoe
10/10/2012 4:02:16 AM • Ariens Zoom 42... • Answered on Oct 10, 2012
Mower starts, but when I engage the blades the mower stalls
check the safety switches
9/4/2012 1:58:24 AM • Ariens Zoom 42... • Answered on Sep 04, 2012
2answers
When turning on pto blows
Look over the entire wiring harness wherever it may be touching metal as it probably is chaffed, simply tape and zip tie it away from the ground source.
7/4/2012 2:30:46 PM • Ariens Zoom 42... • Answered on Jul 04, 2012
Ariens Zoom 42 In 165 HP Briggs  Stratton Zero Turn Riding Mower () Logo
Popular Tags
42 questions posted
Top Ariens Garden Experts
john h
Mike Cairns
Mike Cairns
CJ Rock
CJ Rock
Are you an Ariens Garden Expert? Answer questions, earn points and help others
View Most Popular
Ariens Garden
  • Ariens Garden
Most Popular Question
battery full charge when try start not
  • Garden
