20 Most Recent
Vision Fitness T9500 Treadmill Questions & Answers
Error lines in function area
Dear Sir:Adjust the reed switch, clean and tigh the connector very well, see the diagram attached2) tight the ribbon cable from keypad +tight connector from display board vs lower board3)If the problem persist run the software calibratin for diagnose, troubleshooting and fix it. See my personal TIPS FOR HELPsincerely. God bless you
Error messages error lines
Dear Sir:Adjust the reed swtich see the diagram attached, clean, and tight the connector very well.tight the ribbon cable from keypad, and connector for display board vs lower board.If the problem persist you must run the software calibration for diagnose and troubleshooting.sincerely. God bless you
The t9500 treadmill will slow down in speed and increase in incline. i unplug it then it will behave for awhile, then it starts doing the slowing down and increase the incline.
1) Test the Speed sensor and adjust the same as intructed in your owner manual 2) Plugin very well the connector and clean. 3)exchange batteries by new one in the display board 4) tight the flexible cord from keypanel vs display board 5) tight the connector from display board vs lower board very well. 6)Now test the main motor if is faulty ( short winding) 7) main motor controllber board is faulty ( test the 115VAC + 5VDc for por supply input coming 8) Power transforner maybe faulty.See the block diagramm that i Did FOR you kno how the main motor board has aprox 90% of functions of any treadmills. Now you will have strong DIAGNOSTIC, for to measurement the answer Right.
sincerely.G-d bless you.ERNESTO CUADRAMANAGUA,NICARAGUA. C.A
