20 Most Recent Coleman Cable Coleman Twomantle Dual Fuel Powerhouse Lantern () Questions & Answers
Acts like a check valve is stuck open below the
It sounds like you are correct. While I don't know much about the new lanterns I have worked a lot on older ones. My first suggestion is the easiest. Try putting some 3 in 1 oil on it. First relieve any pressure in the tank- open the valve then slowly loosen the fill cap- watch out as it will likely spill fuel so do this outside Remove the plunger, there is a black plastic piece that holds it in it will come of either by a push and twist, or by removing a little metal bail across it. (you remove the metal bail (small wire loop) by gently pulling it outward with a small pliers.) then the plunger should come right out look into the hole and you will see a check valve at the bottom, try a bit of oil or wd40 on this, let it sit for a while, it may just be rusted open, and will take some time for the oil to work. Make sure it is working well before you light the lantern. you Do Not want this to fail when the lantern is going. Do this outside and away from any flames. Pump it up and see if it can hold pressure overnight
12/1/2016 3:59:08 AM • Coleman Cable... • Answered on Dec 01, 2016
My coleman powerhouse dual fuel
Hi bradley m925...
Try using the cleaner for the generator, it is a twist type crank, make a few turns on it if you have it.
If not then your right, replace the generator as it is faulty.
Please take time to rate me
Coleman Generators website...http://www.summitcampinggear.com/lage.html
9/21/2011 11:44:43 PM • Coleman Cable... • Answered on Sep 21, 2011
I have a dual fuel,
Make sure that the vapourised fuel is coming through the mantle before lighting up. You should hear a hissing sound when the flame adjusting lever is turned to high. If not it is possible that the generator is clogged up and that vapourised fuel is not getting through to the mantle. So when you light up you are essentially just burning the mantle. If the generator is knackered it will need to be replaced. One way to check it to remove the generator, primed the tank and turn the valve on. If fuel spurts out when the generator is removed (DON'T LIGHT IT U)P THOUGH) but there is no hissing sound when the generator is intact then it is a sure sign that the generator is clogged up. In the UK a replacement generator should set you back £10-15. Hope this helps, Bandit
5/25/2011 4:14:26 PM • Coleman Cable... • Answered on May 25, 2011
I have a Coleman single
what kind of fuel are you using
11/26/2010 2:04:48 AM • Coleman Cable... • Answered on Nov 26, 2010
My coleman dual fuel lantern wont let me pressure
Remove the plunger and oil the leather diaphram with light oil similar to 3 in 1 oil, and expand the diaphram until it is no longer stiff and contracted. If you do not know how to remove the plunger let me know.
9/16/2010 4:38:57 PM • Coleman Cable... • Answered on Sep 16, 2010
Where can I find replacement parts for my rechargeable lantern?
It's great that you're looking to revive your rechargeable lantern! Here are some steps you can take to find replacement parts and ensure your lantern is in working condition:
  1. Check with the Manufacturer: Start by contacting the manufacturer of your rechargeable lantern. They may offer replacement parts for your specific model, including the light tubes. You can inquire about replacement batteries as well.
  2. Search Online Retailers: Look for online retailers specializing in selling replacement parts for lanterns and flashlights. Websites like Amazon, eBay, or specialized outdoor equipment stores may carry the replacement light tubes you need. Make sure to check if they ship to Canada.
  3. Visit Local Hardware or Outdoor Stores: Explore hardware stores, camping supply stores, or outdoor equipment retailers in your area. They may have replacement light tubes or similar products that are compatible with your lantern.
  4. Consider Universal Light Tubes: If you cannot find the exact replacement light tubes for your lantern, consider purchasing universal light tubes that fit the size and specifications of your lantern's sockets. Be sure to measure the dimensions of the sockets and compare them with the specifications of the replacement tubes.
  5. Test the Battery: Before purchasing replacement parts, it's a good idea to test the battery to see if it still holds a charge. If you have a compatible charger, you can try charging the battery and observing its performance. If the battery no longer holds a charge or shows signs of leakage, you'll need to replace it.
  6. Inspect for Damage: Since the lantern has been in storage for several years, carefully inspect it for any signs of damage or wear, especially around the battery compartment and electrical components. If you notice any corrosion or damage, it's best to address those issues before using the lantern.
By following these steps, you should be able to find replacement parts for your rechargeable lantern and get it back into working condition. If you encounter any difficulties, don't hesitate to contact customer support or seek assistance from a local retailer.
4/16/2024 9:58:57 PM • Camping,... • Answered on Apr 16, 2024
What amp and volt charger do you need to charge the tw-308 taser flashlight
Not sure of the legality of the secondary function! https://www.google.com/search?q=tw-308+taser+flashlight+charger ..
4/9/2024 11:03:17 PM • Camping,... • Answered on Apr 09, 2024
La-Z-Boy Slumber air mattress. How to repair a leak in one please?
Question edited for clarity, correct order and spelling of maker. Duplicate question deleted, Refresh page to see your question. Repairing leaks is easy if you can find it and depending where the leak is? Information and videos in the link https://www.google.com/search?q=La-Z-Boy+Slumber+air+mattress.+How+to+repair+a+leak ..
4/9/2024 11:00:55 PM • Camping,... • Answered on Apr 09, 2024
I have Illumibeam Lantern, Crank Up. It has a plug in the wall don't know how it work. I plug it in, no lights no nothing.
This one? https://www.ebay.com/itm/335145703247 They are a bit of a gimmick, and of course are made for $2 in China. The way they work is that they contain a small rechargeable NiMH battery. You can charge it via the wall adapter, or you can turn the crank which operates a small generator to charge the battery. It is likely that you can't run it directly from the mains, but it should light when you remove the charging cable and switch it on. ..
3/21/2024 5:05:42 PM • Camping,... • Answered on Mar 21, 2024
2answers
Lost assembly instructions for my Stockman Wimmera 8 Person Tent. Can you help me? ThankYou!
It's a bit old/dated and a few holes...but think this should do the trick: 9c803efb-edc7-4048-b15a-09c281fa2915.jpg
3/8/2024 4:33:04 AM • Camping,... • Answered on Mar 08, 2024
BLACK+DECKER SL3WAKB: Compact 300 Lumen LED Spotlight Flashlight. How to replace bulb in flashlight SL3WAKB
It carries an LED Module, so they aren't like replacing a halogen bulb, you have to replace the whole module with the LED. Just replace the whole lamp for 10 bucks!
BLACK+DECKER SL3WAKB: Compact 300 Lumen LED ...
AZ Electronics https://azelectronics.ca > products > sl3wakb-bla-compa... BLACK+DECKER SL3WAKB: Compact 300 Lumen LED Spotlight Flashlight · LED delivers bright beam of light · Compact and lightweight design · Power saver setting to ... $9.99 · ‎ In stock ..
3/5/2024 4:41:29 AM • Camping,... • Answered on Mar 05, 2024
How do l replace batteries in a vintage Dorcy 41-1015 dual spotlight?
It looks like you unscrew the plastic lens and remove the bulb and reflector like the old Pifco versions. https://www.google.com/search?q=Dorcy+Focusing+Lamp+Dual+Spotlight%2F+Model+41-1015+replace+battery ..
2/14/2024 12:38:48 AM • Camping,... • Answered on Feb 14, 2024
2answers
Do you need special hiking shoes for going on long walks?
Whether or not to buy hiking shoes really depends on what kind of walking you plan to do and how often.Hiking boots are helpful for rougher terrain and for gripping. If you plan to mostly walk on flat ground, you can consider getting good walking shoes instead.
1/25/2024 4:10:25 AM • Camping,... • Answered on Jan 25, 2024
What is camp furniture?
Camp furniture is items like tables and chair that are madeout of a durable material, are light and can be folded up and packed.
1/10/2024 2:37:49 PM • Camping,... • Answered on Jan 10, 2024
2answers
Propane lantern burns yellow light not bright white while we are fishing
Doesn't that suggest a blocked nozzle, requiring first a quick probe with a "pricker"?
12/17/2023 10:42:37 AM • Camping,... • Answered on Dec 17, 2023
Nebo Big Daddy flashlight.
Question moved from Cars and Trucks category to Flashlights. Apparently not easy if you use the 3 x AAA battery cartridge. Unscrew the base. https://www.amazon.com/ask/questions/Tx1DKW5P7LJ9IXV/ Sometimes they will take a rechargeable 18650 instead. https://nebo.acgbrands.com/en_US/lights/replacement-batteries.html https://www.arcade-electronics.com/v/vspfiles/nebo/120REDLINE%20Big%20Daddy%20User%20Manual.pdf ..
12/15/2023 1:01:54 AM • Camping,... • Answered on Dec 15, 2023
2answers
I need a new bottom for the Tinkerbell Lantern.
There are no parts for them. You just buy a new one. Or you might have someone 3D print you one. https://www.google.com/search?q=tinkerbell+lantern ..
11/23/2023 12:27:34 AM • Camping,... • Answered on Nov 23, 2023
How to open the coast px45 flashlight
Purportedly, twist the tailcap counter-clockwise.
11/1/2023 7:31:49 PM • Camping,... • Answered on Nov 01, 2023
Coleman Cable Coleman Twomantle Dual Fuel Powerhouse Lantern () Logo
9 questions posted
Top Coleman Cable Camping, Backpacking & Hiking Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Coleman Cable Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
View Most Popular
  • Coleman Cable Camping, Backpacking & Hiking
Most Popular Question
coleman single
  • Camping, Backpacking & Hiking
