20 Most Recent
Citizen Cortina Eco-Drive BM8194-50L Wrist Watch Questions & Answers
Hi I have a quartz woman's watch that I bought
Save your nerves and your money. Visit your nearest watch repair shop and ask to get links out. If you will try to do it yourself, you will loose your strap as you wont be able to put it back together. If you anyway decided to do it yourself, click on my profile and check out my solutions. I do explained all this tricky job to one customer about a year ago, so, you will definitely find it if you have enough patience to go through all my solutions. Rate me plz.
How do I adjust the band
If it has a clip-style wrist attatchment, you may slightly adjust the pins a couple of inches with a small pin to remove thte sppring and re-insert in another hole. I recommend tweezers and a clean work surface. The spring MAY fly, so ask someone to hold their hands over the area you are working on. If you need more adjustment, go to a jeweler to have links removed /added.
Citizen eco-drive wr 200 manual
I'll need more information about the watch. WR200 is not the model number. It is the depth in metres it is water resistant to.
The serial number is usually engraved on the back plate of the watch. The bit against your skin when you're wearing it. It's the number marked in red in the photo I've attached. Is this a digital watch, a watch with hands or does it have both?
Comment below with the serial number and I'll try to help you more.
I have an old Citizen
hi, I'm from Italy and changed the batteries just 2 days ago - theer are three batteries inside this watch - in a normal shop selling citizen watches.....
I think youhave just to change shop....
