20 Most Recent Singer Pixie Plus Sewing Machine Questions & Answers
2answers
Pixie plus sewing machine needle does not go down into the bobbin but hits the metal plate on top of the bobbin. The needle cannot go through the sewing slot.
Sounds like your needle is set to off-center. Check your manual. You may have a straight-stitch plate in your machine but you have it set to stitch off center or it is set to zig-zag stitch and the needle is unable to clear the stitch plate. ...
10/22/2022 7:23:38 PM • Singer Pixie... • Answered on Oct 22, 2022
When I spin the wheel, Why don't the needle and take up lever move?
Check bobbin winder is in sewing position and not winding position.
1/18/2021 2:18:02 PM • Singer Pixie... • Answered on Jan 18, 2021
How to disassemble the machine to put a screw back in?
Hello, here is website to download manual that you are wanting. Singer Pixie Plus the crafting machine by SINGER Instruction Manual
11/26/2015 12:43:10 AM • Singer Pixie... • Answered on Nov 26, 2015
So when I start sewing it works for a few seconds then my top thread breaks and or wraps its self around the black casing the bobbin sits in. What am I doing wrong?
Be sure to RAISE the presser foot BEFORE threading the upper thread. This releases the tension disk so the thread can seat properly. If upper thread is breaking soon after beginning to sew, it usually is because the upper tension is too tight. Try loosening it and re-testing. The upper and lower threads should meet in the middle of the fabric. ...
9/22/2015 5:56:59 PM • Singer Pixie... • Answered on Sep 22, 2015
After you stitch about two inches the top needle thread wraps around the bobbin stopping the machine.
try these suggstions 1. new needle--one for the fabric being used--flat side always goes to the back--make sure the presser foot in up 2. make sure the thread has not come off the thread take up lever 3. rethread the machine--use Every Thread Guide
6/15/2015 6:15:52 PM • Singer Pixie... • Answered on Jun 15, 2015
Bobbin holder won't stay in
the bobbin holder may need to be replaced, the hook and hook race may need to be checked to see if there is something wrong with them.
6/15/2015 6:08:53 PM • Singer Pixie... • Answered on Jun 15, 2015
2answers
Not able to draw the thread up from the bobbin by turning the know toward me. I have rethreaded etvc. It looks like a piece is missing for the bobbin to rest in, nothing to catch the thread.
Warranty? pursue that first with the seller, some will exchange in cooperation with the mfg and simpler to do. You will need your sales receipt. Especially if it never worked, or has broken through no fault of your own. Trying to repair, may invalidate the warranty if there is one.
6/15/2015 3:47:29 PM • Singer Pixie... • Answered on Jun 15, 2015
tip
How to keep bugs away from you when you are outside
Rub dryer sheets on your skin and it will keep mosquitoes and other pests away! :)
2answers
What is the best thread to use on the pixie plus machine. A lot of the threads do not fit.
I am not sure why they would not fit but embroidery thread is thinner than general purpose thread so it might work. Good luck.
3/26/2015 6:03:10 PM • Singer Pixie... • Answered on Mar 26, 2015
2answers
I am hitting the bobbin holder with the needle. How do I install the bobbin holder to correct this situation
Sounds like your placement is off. Check your instrutions or look on line for the manual. I hope this is helpful, at least point you in the right direction.
3/19/2015 10:02:00 AM • Singer Pixie... • Answered on Mar 19, 2015
2answers
How to remove the housing to change the light bulb iin a singer pixie plus
Most machines have a screw on the end or back that holds the end cap on that covers the bulb and mechanical parts. Sometimes they are hinged too. If the bulb is underneath in the middle then that may take a little bit more to get at it. I agree with Matty W too that Singer is really good at helping with fixing and replacing the bulb or other small fixes. I have done live one on one chats with them and they are very knowledgeable and patient. Good luck.
2/4/2015 6:49:20 PM • Singer Pixie... • Answered on Feb 04, 2015
Pixie plus bobbin issues
Could you please be more specific? Are you having problems getting the bobbin in?
11/29/2014 5:02:36 PM • Singer Pixie... • Answered on Nov 29, 2014
How should the bobbin and casing be lined up?
If you will do a search on "Singer Pixie Plus Manual," you will be forwarded to the Singer site, and if you scroll down, there is a link to the instruction manual. In the Google listing, below that is a YouTube video, demonstrating your machine. Here's the link to the manual: http://www.singerco.com/support/instruction-manuals/search?man_model_no=Pixie+Plus
11/9/2014 3:06:06 AM • Singer Pixie... • Answered on Nov 09, 2014
How is the bobbin case retimed?
This question comes up a lot here. My first question is always--why do you think the timing needs to be reset?
10/31/2014 6:57:57 PM • Singer Pixie... • Answered on Oct 31, 2014
Loosen the thread tension when already set on 8?
If you don't have the manual, you can get it free here: http://www.singerco.com/uploads/download/612_pixie_manua%28tri-lingual%29l.pdf It takes a while to download because there are 24 pages and are in a few different languages. You should be using a metal bobbin. Hope this helps. M
10/21/2014 4:19:11 AM • Singer Pixie... • Answered on Oct 21, 2014
Singer Pixie Plus Sewing Machine Logo
80 questions posted
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Singer Sewing Machines
Most Popular Question
when start sewing works few seconds top
  • Sewing Machines
