20 Most Recent Tefal FZ700015 Deep Fryer Questions & Answers
3answers
My tefal actifry paddle wont turn
3 star key screws on the base of the unit, loosen the power cable from its clips then with a flat head screwdriver separate the 2 plastic parts starting from the back taking care not to damage the fan motor.I managed to get my motor working with a bit of a clean and making sure the motor and paddle were aligned or a new motor swap involves 2 screws and push on connectors, no soldering.
12/6/2012 2:56:40 AM • Tefal FZ700015... • Answered on Dec 06, 2012
Where can I find a Tefal toaster schematics?
Usually nowhere. On a standard 2 or 4 slice toaster the elements come as a one piece cassette. Very difficult to replace. I have one in my garage. I bought it and then opened up the toaster, there are about 20 SOLDERED connections!! I bought a new toaster. There is one here https://www.ifixit.com/Guide/Tefal+Thick+N+Thin+Toaster+815032+Disassembly/136882 Generic information as no model details. Throw it away and buy a new one. https://www.google.com/search?q=tefal+toaster+schematics ..
3/22/2024 11:21:59 PM • Tefal Kitchen... • Answered on Mar 22, 2024
My Tefal 8 in 1 cooker stopped working. It shows E0 in its LCD display when I try to switch it on. Can you help me.
Tefal website: https://www.tefal.com/faq/Products/Electrical-Cooking/Rice-cooker/8-in-1/csp/7211000792 WHY DOES THE « E0 » ERROR CODE APPEAR ON THE LED SCREEN? The top major sensor has an open circuit or there is a short circuit. You will need to send this to a Authorised Service Centre for repair. The sensor is the springy disc in the middle and can be replaced.
3/18/2024 6:56:16 PM • Tefal Kitchen... • Answered on Mar 18, 2024
Tefal Actifry 2 in 1 paddle is going backwards. Can anyone help fix this?
These devices use a synchronous motor, and they work on AC current cycles rather than voltage. Normally you can make them reverse two ways. Unplug and reconnect quickly until it runs the right way. or make it turn the right way by hand before turning it on by giving it a hand in the correct direction. But backwards is not a problem, mine goes both ways. ..
2/29/2024 6:54:10 AM • Tefal Kitchen... • Answered on Feb 29, 2024
How can I disassemble a Tefal Easy Fry EY1018 airfryer?
  1. Unplug the air fryer: Before starting any disassembly, ensure the air fryer is unplugged from the power source to prevent electrical accidents.
  2. Remove the basket and pan: Take out the cooking basket and pan from the air fryer and set them aside.
  3. Locate screws or clips: Examine the exterior of the air fryer for any visible screws or clips that hold the casing together. These are typically located on the underside or at the back of the unit.
  4. Remove screws or clips: Using the appropriate tools (such as a screwdriver or pry tool), carefully remove the screws or unclip the casing to access the internal components.
  5. Separate the casing: Gently pry apart the casing of the air fryer, being mindful not to force it and to avoid damaging any internal components.
  6. Disassemble internal components: Once the casing is removed, you may have access to the internal components of the air fryer, such as the heating element, fan, and control panel. Take note of the arrangement of parts and any connections.
  7. Proceed with caution: Handle internal components carefully and avoid causing damage or disconnecting any wires or cables unnecessarily.
  8. Reassemble: After completing the necessary maintenance or repairs, carefully reassemble the air fryer in the reverse order, ensuring all parts are properly aligned and securely fastened.
  9. Test the air fryer: Before using the air fryer again, plug it into a power source and test that it functions correctly.
If you're unsure about disassembling your Tefal Easy Fry EY1018 air fryer, it's advisable to consult the user manual or seek assistance from a qualified technician or customer support representative.
2/10/2024 6:19:29 PM • Tefal Kitchen... • Answered on Feb 10, 2024
2answers
I am looking for a paddle for my tefal bread maker
You can find a paddle for your Tefal bread maker on Amazon or other online retailers. Some paddles are universal so you can make sure to get the right one for your specific bread machine.
10/31/2023 5:53:24 PM • Tefal Kitchen... • Answered on Oct 31, 2023
My handle of my tefal secure 5 pressure cooker came unattached and I need to assembly it again, but I need some kind of drawing to help me
I couldn't find the Secure 5 lid but I found another brand that is very similar in design and assembly that might be helpful as a guide - FAGOR Pressure Cookers Removal and Replacement of Lid Handle
9/24/2023 4:10:06 PM • Tefal Kitchen... • Answered on Sep 24, 2023
My tefal actifry family series 011-1 stops working after 4 minutes. er shows in the digital screen and stops working Switch off for 10 seconds starts again but stops again every time
  • The temperature sensor might be faulty. The temperature sensor is responsible for detecting the temperature of the oil in the Actifry. If the sensor is faulty, it might not be able to detect the correct temperature, and the Actifry might stop working as a safety precaution.
  • The thermostat might be faulty. The thermostat is responsible for regulating the temperature of the oil in the Actifry. If the thermostat is faulty, it might not be able to keep the oil at the correct temperature, and the Actifry might stop working as a safety precaution.
  • The oil might be too low. The Actifry needs a certain amount of oil to function properly. If the oil is too low, the Actifry might stop working as a safety precaution.
8/6/2023 12:59:52 AM • Tefal Kitchen... • Answered on Aug 06, 2023
Where can I purchase a tefal repair manual from
I think that by searching on ebay you will easily find this manual.
6/12/2022 6:18:32 PM • Tefal Kitchen... • Answered on Jun 12, 2022
Tefal actifry express error 1.
The fan is not working. Check that all removable parts are fitted and correctly positioned ( bowl ventilation output grid and removable filter, pan, lid) Check that there are no foreign bodies is all of these removable parts.
5/12/2021 4:38:13 PM • Tefal Kitchen... • Answered on May 12, 2021
How i fix error 6 tefal actyfry ah9500??
your mains voltage is too high and the device is protecting you against fire. E6 Error The voltage of your domestic network is too high; for safety reasons your appliance should be protected against the risks of overheating.
Actifry tefal error 6 - Tefal Actifry - iFixit
https://www.ifixit.com > Answers > View > Actifry+tefa...
4 answers May 14, 2019 - I read somewhere that it may be caused by some fuse behind the display (soldered on) and/or faulty motor. I am planning to disassemble my ...
Table Of Error Codes: Er. - TEFAL ActiFry express XL AH950 ...
https://www.manualslib.com > ... > User manual
TEFAL ActiFry express XL AH950 Manual Online: Table Of Error Codes: Er.. Er. 1 or 2 Er. 3 Er. 4 Er. 5 Er. 6 ENVIRONMENT PROTECTION FIRST ! i Your ...
5/8/2021 11:08:23 PM • Tefal Kitchen... • Answered on May 08, 2021
Tefal GV9360 causing mains failure
I guess what you mean is your steam generator is tripping one of the breakers in your consumer unit. If it is the RCD it means current is leaking to ground. If it is an MCB it means there is a short circuit or overload. Both conditions mean the unit needs some serious looking at and with a portable appliance it is worth checking the power cord and plug for damage or loose wiring, however steam generators of various types and steam irons that these days the manufacturers claim can be used with tap water (straight from the faucet) can still suffer from limescale problems in hard water areas. Water dumps it's mineral content at 140 degrees F. Scale build up on the heating element will tend to break away due to the expansion as it heats but stubborn bits will remain tending to cause hotspots and uneven heating and uneven expansion hastening element failure. That might be your problem and a multimeter won't always find it. Sometimes there is visible evidence and sometimes it needs a test with a Megger. Of course it might be something else...
1/5/2021 12:33:42 PM • Tefal Kitchen... • Answered on Jan 05, 2021
Why does Tefal cook 4 me show code 24?
Hi there, YouTube has loads of advice on the tefal cook4me, you may be able to get your resolution there, Good luckm
4/2/2019 2:57:27 PM • Tefal Kitchen... • Answered on Apr 02, 2019
HB643538 tefal Optichef service manual.... thank....
ManualsLib Makes it easy to find manuals online Try this link to find the manual you are looking for,
3/29/2019 11:44:53 PM • Tefal Kitchen... • Answered on Mar 29, 2019
2answers
TEFAL Optigrill GC701D40 sensor problems
I had the same problem and phoned Tefal customer services. Underneath the top plate, in the bottom left hand corner, there is a small button. This is actually the quickness sensor, and if you clean this it should resolve your problem.
12/17/2018 7:17:42 AM • Tefal Kitchen... • Answered on Dec 17, 2018
tip
How to Fix a Vegetable Steamer
Fixing a clogged up veg steamer, see video.
Tefal FZ700015 Deep Fryer Logo
5 questions posted
Top Tefal Kitchen Appliances - Others Experts
ADMIN Andrew
ADMIN Andrew
Ngoro
Kardoc
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Tefal Kitchen Appliances - Others
Most Popular Question
  • Kitchen Appliances - Others
