20 Most Recent
Speed Queen AWN412 Top Load Washer Questions & Answers
How do i take agitator
To remove the agitator all that ya need to do is grab the bottom edges of it and pull it straight up and out..if locked onto a hub under it and is just held to that hub by several tabs
Gene
Washer stops in middle of cycle,before rinse.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
How do I replace broken washer cycle selector knob
Hello there and thank you for choosing fixya
These knobs are normally the pull off type so all you have to do is get a small flat tip screw driver behind the knob and gently pry it out to get it started then it should slide off
However if you are needing to replace the entire part then the top back section of the machine may need to come off it may even have some screws behind the white side plates that allow to be removed and the top part folds up and back allowing you to axcess the part ok this part is usually held on by 2 or 3 screws
Speed queen washer shown er65
The Speed Queen error code 65 occurs when the washer's main control board detects a problem with the door switch. The door switch is a safety feature that prevents the washer from operating when the door is open. When the main control board detects an issue with the door switch, it will display the error code 65. There are a few reasons why the door switch may be malfunctioning. The most common reason is that the door switch is dirty or obstructed. Another possibility is that the door switch is loose or damaged. If the door switch is damaged, it will need to be replaced.
Speed Queen Washer displaying codes TL 05. 00 D5
Yes, good diagnostics and summary. Don't guess with control boards for exactly the reason you stated. Call for service, you need the correct diagnosis and warranty on the part and the service call. There are indeed expensive and not for guessing.
