20 Most Recent Duraflame Powerheat 1500W Infrared Quartz Heater w Timer & Remote - Cherry - Questions & Answers
Turns on for 1 minute and gets Er - I cleaned filter
It may be getting too hot and activating the safety shut off. This may need a new board. I have never worked on one of these but it has to be fixable. Depending on the cost of the unit as to whether or not it is worth it.
3/4/2016 2:13:16 PM • Duraflame... • Answered on Mar 04, 2016
Where to get a copper gas line for Endless Summer 230000 Patio Heater?
Could you use a compression fitting across the break? If you can take a piece of the tubing to local hardware/auto store for sizing to see how snug the brass ring is.
2/16/2023 11:57:44 AM • Patio Heaters • Answered on Feb 16, 2023
Sahara big burn patio heater
From the Troubleshooting Guide - Check the Obvious Turn on the gas and listen at the burner to see if you can hear the gas arriving. If the patio heater has an electronic ignition system make sure that there is a spark. If there is a spark but the heater will not light up, try using a lighter or burning spill to light the gas. Be ready for a flash over if you have been trying to light the gas for a while-there might be a small cloud of gas near the burner. Start at the Bottom The most likely reason that a gas heater will not work is that there is no gas. Take out the empty gas cylinder and replace it with a full one. Often you will feel that there is still gas in an empty cylinder but there is not enough to create the pressure needed to drive the gas burner. An empty cylinder will feel light. Check the Gas Regulator The gas regulator is the connection of the gas cylinder to the gas pipe that takes the gas up to the burner. Some regulators have a flip switch that prevents the valve in the top of the cylinder from being depressed-effectively an "off" switch. If there is such a switch, make sure that it is in the "on" position. Check the Gas Pipe Although it is most unlikely that the gas pipe can get blocked, remove the gas pipe from the regulator and from the gas inlet at the top of the heater. This pipe is pressure fitted and held in place by pipe clips. Blow air through the pipe to ensure that it is clear. Check the Burner The burner will be a very simple assembly. Take each part off in turn and check for any blockages. Also check that the burner apertures are set correctly. Beneath each burner is a small chamber in which air and gas are mixed. Make sure that the gas and air inlets are clear. If Your Heater has a Pilot Light If your heater has a pilot light, there is the possibility that the thermo couple has failed. The thermo couple is usually shaped like an inverted "v" and sits in the flame of the pilot light. The temperature acts on the thermocouple to keep the gas supply to the burner open. A good indication that the thermocouple has broken down is that the pilot light goes out when you try to turn the heater on. Thermo couples are readily available patio heater parts and usually available from stock. If you have carried out all the checks and the heater will still not light, you can repeat all the checks more slowly and carefully or take your heater to a specialist for a service. If you need further help, I’m available over the phone at https://www.6ya.com/expert/steven_7f54ab9063554f66
2/16/2023 11:52:50 AM • Patio Heaters • Answered on Feb 16, 2023
2answers
I have 2 sunjoy G-PH001PSS, when attached to the
Greg... The lighting PROCESS involves HOLDING that "PRESS MODE" for QUITE a (long) WHILE... To clear the AIR out of your fuel line... I have seen ... Up to 5 minutes (although I believe that is excessive)... It is MOST LIKELY your troubles are procedural. (READ the manuals) ELSE Blue Rhino is the place to START ... or SEARCH locally on the internet... Try (they have manuals here... also) Blue Rhino Outdoor Gas Heaters Hope this helps Carnac the Magnificent
7/12/2018 4:21:40 AM • Patio Heaters • Answered on Jul 12, 2018
4answers
Are electric patio heaters bad for the environment?
there has been some debate about it, in America they are seen as environmentally friendly, but in the UK they are seen as more carbon intensive
10/13/2016 5:22:06 AM • Patio Heaters • Answered on Oct 13, 2016
Hi i have a progaz heater the the pilot light won't stay on it starts the heater then flickers for a bit the go's out
Defective thermocouple. It is the metal tube that stays in the path of the pilot light flame.
8/31/2015 7:52:00 AM • Patio Heaters • Answered on Aug 31, 2015
Pilot light bright yellow
Need to clean or replace it,supply tanks is empty, low pressure,bad regulator, not enough air supply etc. Kinked supply lines.?
9/17/2014 5:27:30 PM • Patio Heaters • Answered on Sep 17, 2014
What is a thermocouple replacement for patio heater metric threads
Not sure, Most universal kits will work. Take old one with to get replcement, sometimes depends on milli-volt out put also.
9/17/2014 5:25:35 PM • Patio Heaters • Answered on Sep 17, 2014
My propane outdoor heater lights and generates heat on low but when i turn control to high the flame and heat do not increase
The troubleshooting manual says low fuel, low fuel and cold weather and kinked supply line. Beyond this I would need to know if something happened to the unit like it fell over or was taken apart. Best, Joe 1_31_2014_3_36_44_pm.png
1/31/2014 3:36:44 PM • Patio Heaters • Answered on Jan 31, 2014
My patio heater says it burns LPG. what does that stand for?
LPG stands for Liquefied Petroleum Gas, it is very common in patio heaters
1/23/2013 11:16:37 AM • Patio Heaters • Answered on Jan 23, 2013
Duraflame Powerheat 1500W Infrared Quartz Heater w Timer & Remote - Cherry - Logo
1 questions posted
Top Duraflame Patio Heaters Experts
deton8 von Splosion
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you a Duraflame Patio Heater Expert? Answer questions, earn points and help others
View Most Popular
  • Duraflame Patio Heaters
Most Popular Question
turns 1 minute gets er cleaned filter
  • Patio Heaters
