20 Most Recent
Motorola Mobility W270 Cell Phone Questions & Answers
Network problem
First Option:Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved SoSecend Option:Your Phone Network IC Fault So Please change Network ICAnd Network Signal Problem will Solvedif it is there isn't much you can do on this side of the network.Contact your phone company.
10/29/2012 1:44:37 PM •
Motorola...
Answered
on Oct 29, 2012
Hello i want to use
Try to plug your phone to other USB port in your PC I will recommend to plug it at the USB port at the back of your CPU. USB supply of power at the back of the CPU is sufficient to make your device function properly so it may be able to detect by the system..mostly device can't recognize by the system because they didn't function properly specially if they are plugged in a USB port who don't have enough supply of power to make them work properly..Hope it may help you..
7/11/2011 2:56:15 PM •
Motorola...
Answered
on Jul 11, 2011
MEMORY card
Hello there
Insert your memory card into your computer's reader if you have one. If
not, you can purchase a multi-format USB Memory Card reader from
Amazon.com or Buy.com
Open up 'My Computer'. You should see it under the list of available
drives.
Check its contents first to make sure that you have the right drive.
In 'My Computer', right-click on the drive and choose 'Format'.
5
Leave all the options as they are and click on 'Start'. This is a
non-reversible process so make sure this is what you truly wanted to do
in the first place.
6
Once the process is completed, take the memory card out and insert it
into your Digital Camera or any other device. Try to browse to it to
make sure it works fine now.
8/27/2010 7:58:29 PM •
Motorola...
Answered
on Aug 27, 2010
How to flash?
hello all you need to just take it to your network provider or call the customer care center
7/22/2010 4:00:56 PM •
Motorola...
Answered
on Jul 22, 2010
