20 Most Recent
Grundig G6 Aviator (Buzz Aldrin Edition) AMFM Radio Questions & Answers
The grundig g6 has sticky case
Sounds like oils from your hands (or someones) over time has reacted to a coating on the radio. Try Isopropyl or denatured alcohol and paper towels and/or cotton balls. Do not be surprised if you loose the coating. The sticky is the body oils de-bonding abd breaking down the rubberized coating.
I just purchased the G6
It sounds like the whole am band is not working which includes the shortwave bands, there is no remedy to correct this and is clearly a manufacture defect. The best solution is return the radio because there is nothing more that can be done in it's present condition.
I have lost my owner's manual. I bought it at
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. To view the manual you will need adobe reader, which you can get for free from http://get.adobe.com/reader/ You probably already have it though, please try opening the file first and find out. Here is the manual / guide please give it a few minutes the file is quite large:
http://shopetoncorp.com/documents/115269/G6_Manual_US_010308_low.pdf
10/13/2010 10:18:05 PM •
Grundig G6...
Answered
on Oct 13, 2010
How to set the stations
The Grundig YB320 and the Phillips AE3650 are the same radio, just manufactured for different companies. A user manual from Grundig is not available, but was able to find one for the Phillips.
Manual for Phillips AE3650In a nutshell, set the band that you want to listen to, tune to the frequency of the station, then press the memory button until M or P appears in the display, then press button 1 through 5 to store your selection.
Replacement battery for grundig satellite 3400 ? Where is it possible to buy?
I think this unit uses 'UM-1' batteries. They are also known as 'D Cell', 'R20' or 'LR20' batteries. Most good electrical, hardware and some of the larger 'supermarket' stores will have these batteries available. A good quality brand like Duracell or Varta should do the job. There is also two separate smaller 'button' batteries in the unit used to power the clock.
Grundig Radio - Smart ForTwo
Hi Carlie, I apologize, however I am not familiar with the code requirement for Grundig Radio. I recommend that you contact the dealership directly and they should be able to help you.
Sticky outside material on the Grundig G8, any solution?
Rubbing 70-90% alcohol applied on a piece of cloth then spread on the radio will eliminate the sticky substance. May need several application and vigorous rubbing. After the process, my Grundig G8 Traveller II looks better than the original rubbery texture. Cleaner too.
