20 Most Recent HTC BH M300 Bluetooth Mono Headset (UK Black) Questions & Answers
0answers
0answers
2answers
How do i pair up
ok you hold the power key 40 second and you see the power light is stable now you find the device from your phone when you able to find the device you are able to pair the device using 0000 pair key.
1/19/2014 10:28:56 AM • HTC BH M300... • Answered on Jan 19, 2014
Dear HTC Experts I recently bought
Hi, For connecting to other devices, press & hold the power button of your bluetooth headset for initiating the discoverable mode. When the led light starts flashing in red color, search for the headset from the phone in which you wanna connect. Open the Bluetooth settings, turn it on and search for new devices and pick from the list and pair the headset. After this, the headset will be auto-connected.RegardsVineeth
10/28/2013 5:54:51 AM • HTC BH M300... • Answered on Oct 28, 2013
My headset is connected but
Can you be more specific? What mobile phone do you use with?
1/14/2013 7:39:07 PM • HTC BH M300... • Answered on Jan 14, 2013
2answers
Battery goes empty after full
Hi,when a battery goes empty after fully charged, means the cell of the battery is weak and can power on the phone for too long.
All you need to do is to replace the battery with another one,charge for about 6 hours before use and every thing will work fine.
10/5/2010 12:18:33 PM • HTC BH M300... • Answered on Oct 05, 2010
2answers
I have a HTC c15w stereo that has a broken component system 1 strap where or what can I do .
Resubmit so item can be understood.
9/6/2017 12:26:30 PM • HTC Audio... • Answered on Sep 06, 2017
0answers
0answers
Mebor HTZ 1200
Be the first to answer 1/27/2014 6:52:08 PM • HTC Audio... • Posted on Jan 27, 2014Be the first to answer
I have a Digitor A2632 Sub Speaker and would like to purchase a second unit (identical) Does anyone have one in good condition to sell to me?
Hi Denis.. Did you ever get another Digitor A-2632 unit? Cheers Martin Ruffell.. P.S. Whereabouts do you live?
7/22/2013 5:53:58 AM • HTC Audio... • Answered on Jul 22, 2013
I have a htc 2050 home theatre system and no users
Who makes it?
Maybe run it by the manufacturer's support site or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usersmanualguide.com
3/10/2011 11:02:20 AM • HTC Audio... • Answered on Mar 10, 2011
When I put movie in
Home theatre systems are usually made and distributed based on regions. Usually there are about 7 regions and players are usually distributed to each region based on the type of disc which will be distributed in that region.
The disc you have is supposed to be distributed to a different region but has found its way to you. Usually the formats on which the discs are made are usually different from region to region. Although there are methods to change these devices to work with any unit.
Hope this solution has been helpful;?
1/2/2011 9:20:47 PM • HTC Audio... • Answered on Jan 02, 2011
0answers
I have a htc tv.
Be the first to answer 12/1/2010 5:32:38 PM • HTC Audio... • Posted on Dec 01, 2010Be the first to answer
Vocalizer 3 output checked cables and swapped out. 1300 watt power adaptor lights up. sound indicator light is on but no sound. tried mono and stereo. power adaptor problem?
If the display is working, you have audio. Check your amplifier. 1300Watt adaptor ... This unit draws a very low power and that is not needed.
4/24/2024 7:18:55 AM • Audio Players &... • Answered Yesterday
How do I change to degree mode on my porpo YH-2000
  1. Power Off: Turn off the device.
  2. Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
  3. Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
  4. Power Off Again: Turn off the device once more.
  5. Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
  6. Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
4/20/2024 8:57:52 PM • Audio Players &... • Answered on Apr 20, 2024
Panasonic SA-PM250 CD stereo system. Tune dab radio sa pm250?
this model SA rather than SC seems to be a Middle East model. The SC version doesn't have DAB. https://www.google.com/search?q=panasonic+sa-pm250+instruction+manual ..
4/20/2024 5:59:04 PM • Audio Players &... • Answered on Apr 20, 2024
HTC BH M300 Bluetooth Mono Headset (UK Black) Logo
Popular Tags
21 questions posted
Top HTC Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a HTC Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • HTC Audio Players & Recorders
Most Popular Question
dear htc experts recently bought
  • Audio Players & Recorders
