20 Most Recent
Planet Audio AP1000D Car Amp Questions & Answers
Wehen I turn the volume up my subs destort and it
if they are 4 ohm dual voice coil wire them to 1ohm and bump do not turn gain all the way you will fry the amp and if you really want to make them kick . write each 1 to 2 ohms and get another amp they are not getting enough wattage for the volume you are trying to run them at and could be the way you have it tuned .
Ap 1000 amp checked wiring
The most common problem for the symptom you describe is a "ground loop". There's a slight difference in the ground potential between the source unit and the amp itself. It may be caused by a ground on one or both of the audio inputs. It may be caused by the amp case itself being fastened to a metal portion of the vehicle. It may be a grounded speaker lead.
Of course the amp itself could be defective.
1) Isolate the problem. Disconnect everything except power, ground, and remote.
2) Connect the subwoofer(s). If the symptom immediately returns, it's most likely the amp ground or a speaker lead.
Planet audio amp logo wont light up
Check to make sure that the "remote turn on" lead is intact. They are usually blue wires.This wire provided a turn on voltage to fire up the amp once the head unit is turned on.
Power light comes on my planet audio ac4001d but logo doesn't light up
Kegan... I tried and tried to find schematics and/or a troubleshooting guide with no luck! Sorry about that...
IF you can open it up, see if you find fried or destroyed parts? Look CAREFULLY for a blown fuse but know they come in MANY configurations now!
IF POSSIBLE, inspect the printed circuit board for any BURNT or open foil paths?
If all else fails ~ send it back to the factory for repairs. You should also receive the latest UPGRADES too and hopefully at least a 30 day warranty?
