Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
The problem is hard water. There is a new product out called the dishwasher filtration system.It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee.You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
The chopper blade assembly with in the pump housing is either clogged or broken, to get to it, you must remove spray arm and remove screws from filter housing. These are size 20 torx, inside sump are 2 more screws size 15 torx, after these are removed you can clean out chopper or replace it.
If it is doing when it is washing, then it likely to be a problem with the pump, but it might just be 'hunting' because the filters are partially blocked. There is the filter that you can see easily, but there is a fine filter underneath that blocks with fine grey lint.
Water left in the bottom can be caused by that because the drain pump is past the filter and is on a timer.
https://www.google.com/search?q=Kenmore+3380957
To open the Kenmore World class dishwasher, follow these means:
Press-and-hold down the "Sani-Wash" button for somewhere around three seconds until the showcase screen counts down from three to nothing. The red "Lock" Drove ought to now douse and you ought to now have the option to get to each of the buttons on the control center.
If you're experiencing an ERR code and flashing lights on your Kenmore dishwasher model 587, it indicates an error or fault in the dishwasher's operation. Unfortunately, without specific details about the error code or which lights are flashing, it's challenging to provide a precise solution. However, you can try the following troubleshooting steps:
1. Check the owner's manual: Refer to the dishwasher's manual for a list of error codes and their meanings. It should also provide troubleshooting steps specific to your model.
2. Power cycle the dishwasher: Turn off the dishwasher by unplugging it from the power outlet or shutting off the circuit breaker that supplies power to it. Leave it disconnected for a few minutes to ensure a complete power cycle. Then, plug it back in or switch the circuit breaker back on.
3. Check for obstructions: Inspect the dishwasher's interior, specifically the spray arms, filters, and drain pump, for any obstructions such as food debris or foreign objects. Clean or remove any blockages that you find.
4. Run a diagnostic cycle: Some dishwashers have a diagnostic mode that can help identify the cause of the error. Refer to the manual for instructions on how to initiate the diagnostic cycle.
5. Contact customer support: If the issue persists or you are unable to determine the cause of the error, it's recommended to reach out to Kenmore customer support or a qualified appliance repair technician. They will be able to provide further assistance and help resolve the problem.
Remember, the specific steps and options may vary depending on your dishwasher model. Consulting the owner's manual is always the best course of action when troubleshooting appliance issues.
Unfortunately, that sounds like a control board issue, although if you are lucky, it is just bad connections _to_ the control board.
They are expensive so need correct diagnosis by a tech. Then you get warranty on the parts and the job.
