20 Most Recent
Genius Islim 1300 Webcam Questions & Answers
I have a genius islim 310 webcam and it cant work
Before you can use your webcam in any chat program you have to configure it to that program
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
working OK ?
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
My genius 8mo granddaughter somehow swapped the w,a,s,d keys with the arrow keys. How do I swap them back?
are you talking like off of the keyboard? they snap off but not always back on- simply pry the keys up and place the key in the desired spot with the correct orientation and push down firmly supporting the natural action of the button. do this for every button- if the keys were switched software method (it should not) most computers don't allow you to reassign keys but some might, in this case you would need to follow the manufacture instructions to revert the setting or simply uninstall the software but I'm almost sure your talking hardware because not many code writer will "hook" the keyboard- or change your keypress- its considered dirty practice. Good luck
