20 Most Recent
Motorola Mobility Adventure v750 Cell Phone Questions & Answers
Reset code for verizon motorola v650
You want to know the subsidy code in order to unlock your phone?
The code is assigned by the original service provider the phone was manufactured for so that it cannot be taken to another carrier for activation without their permission.
Most times you will receive the message " Enter Special Code " when you insert a SIM card from a diferent carrier. You will need to
contact the original service provider for further assistance.
7/4/2014 6:41:03 PM •
Motorola...
Answered
on Jul 04, 2014
MOTOROLA ADVENTURE V750 POWERS ON TO VERIZON LOGO
Hi its a good indication that you still have water inside the phone.
to get rid of all the water in the circuts, you will need:
1 get a loner phone ( bcause the process i will show you here takes 10 days minimum to work).
you need a zip container with a lit, some desiccant bags 2 or 3 will do just fine.
salt can also be used as desiccant, but it should not touch the phone, use a papaer envelop or something
2 Blow dry the phone
3 put it in the container without the battery
4 put the desiccant bags inside
5 close it hermetically,
then go hide it in some dark spot for 10 days and be patient
Note that you might need a new battery.
Hope this helps
5/7/2011 9:36:31 PM •
Motorola...
Answered
on May 07, 2011
Motorola Adventure - my phone
This basically a software problem. Upgrade phone's software and this will solve it.I suggest you to go to the authorized service centre of the Motorola and do it.
Thank You
11/23/2010 2:21:24 AM •
Motorola...
Answered
on Nov 23, 2010
How to replace Glass on front of cell, Moto
To replace the glass in the front of your phone, the steps to take are listed as follows;
- After removing your back cover and battery,
remove the screws you see.
- With the four screws removed you can now remove the battery compartment,
- With the battery slot removed you have
access to one of the ribbons which
connects the screen to the main body of the phone. Unclip this (it fits
like a plug and socket).
- You'll now have the phone in two parts,
- Now remove the two screws at the
bottom of the main display. You can then remove the display part which
covers the LCD. This is held on by clips. You need to run your
fingernail along the edge of the housing to release these. This will
release the display up to the point where you see two metal parts (left
and right of the Motorola text). The top part of the display is held on
with double sided tape. To remove the display requires some force to
unstick the tape but be careful not to bend this part back and snap it.
Just try to ease it open and it will eventually unstic,
- then you can replace the glass,
- Reverse the process for reassembly.
Take care
10/31/2010 4:04:06 AM •
Motorola...
Answered
on Oct 31, 2010
V750 won't recognize micro sd card
on your PC via your card reader, look at the properties of your MicroSD card: if is say that the format is RAW or NTFS, reformat it again but specify FAT32 with 'default' packet size.
Before you reformat the memory card. if applicable, make sure that you backup the content to your PC under a new folder.
Hope it helps: let me know how you go.
1/27/2010 8:30:14 PM •
Motorola...
Answered
on Jan 27, 2010
You need to formate the card on the phone to make the phone reconize it. Here is how.
1 From the main screen, press the Center Select
Key (ok) (MENU) to open the menu.
2 Use the Navigation Key to scroll to
(SETTINGS & TOOLS and press the Center Select
Key (OK).
3 Scroll to Memory and press the Center Select
Key (OK).
4 Select Phone Memory or Card Memory and press the
Center Select Key (OK).
5 Select My Pictures, My Videos, My Music, or My Sounds,
and press the Center Select key (ok)
If you selected Phone Memory in step 4, you will also
see Phone Memory Usage. If you selected Card Memory in
step 4, you will also see Card Memory Usage and
Format Card.
1/27/2010 9:42:52 AM •
Motorola...
Answered
on Jan 27, 2010
