20 Most Recent SuperMicro X7DBN-B Dual Lga 771 Xeon/ Intel 5000P/ DDR2/ PCI-E/ V&2GbE Server Motherboard Bulk X7DBN Questions & Answers
2answers
System configuration data error
First check the battery. They have a life of about 5 years. Second, if you have replaced the battery, go to Advanced Setup Features in the BIOS. Select PCI Configuration, and set the Reset Configuration data to YES. Save, continue, shut down and reboot a second time.
7/3/2015 7:48:21 AM • SuperMicro... • Answered on Jul 03, 2015
2answers
System configuration erroe
This is normally the battery. They last about 5 years
7/3/2015 7:21:40 AM • SuperMicro... • Answered on Jul 03, 2015
I can't see my HDD
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
4/20/2011 5:23:41 PM • SuperMicro... • Answered on Apr 20, 2011
Supermicro x9sra Boot up
file:///C:/Users/Wajiha/Downloads/MNL-1281.pdf http://kernelpanik.net/boot-selection-menu-on-supermicro-x9sra/
3/23/2020 7:44:00 AM • SuperMicro... • Answered on Mar 23, 2020
2answers
What video card is compatable with supermicro pdsme+
Any PCI mounted card will work.
11/13/2016 12:18:41 AM • SuperMicro... • Answered on Nov 13, 2016
Intel d915GLVG mother board vrm is short and fun dose not work
An electrolytic capacitor has failed. If one has failed it indicates that the board has overheated, and many other components are also weak. This Intel board is not of good quality. Replace with SuperMicro or Tyan, and improve the cooling airflow in the case.
7/3/2015 6:32:03 PM • SuperMicro... • Answered on Jul 03, 2015
Hardddrive
This is usually a bad hard drive.
7/3/2015 6:16:58 PM • SuperMicro... • Answered on Jul 03, 2015
Supermicro system initializing
The POST process is documented in the user manual under BIOS Post Codes.
7/3/2015 4:53:59 PM • SuperMicro... • Answered on Jul 03, 2015
H8dce no audio
Usual cause. Under the Chip Set Menu in the BIOS Under South Bridge Configuration The setting Audio CODEC Interface has been set to disable.
7/3/2015 4:51:54 PM • SuperMicro... • Answered on Jul 03, 2015
Motherboard beep sound
The "beep codes" are located in your user manual in Appendix B
7/3/2015 4:37:46 PM • SuperMicro... • Answered on Jul 03, 2015
Linux drivers serial
The first place is always the Debian Linux website, because most Linux packages are derived from Debian.
7/3/2015 4:35:39 PM • SuperMicro... • Answered on Jul 03, 2015
Firewire port not detected computer
This is usually caused by the chip being disabled in the BIOS
7/3/2015 4:29:43 PM • SuperMicro... • Answered on Jul 03, 2015
Post code 38
"The BIOS can not shadow the ROM into system memory." This is usually caused by the ROM on a card trying to use the same memory space. Remember all of the ROMs have only the memory addresses from C800 to FFFF in the first megabyte available for shadow. This was designed in in the first IBM PC and remains to this day. Remove the other cards, and turn off both system ROM shadow, and video ROM shadow.
7/3/2015 4:06:50 PM • SuperMicro... • Answered on Jul 03, 2015
PDSMI
If you are good with a soldering iron the capacitors can be replaced. Make sure you can wick the excess solder out of the holes. Replace only with Japanese capacitors, and increase the airflow in the case and around the capacitor. This is usually a sign of overheating.
7/3/2015 3:58:02 PM • SuperMicro... • Answered on Jul 03, 2015
X5da8 4 red LED lits at power on
If the system boots, check the BIOS overheat settings. If no boot, Most common problem, BIOS is corrupted.
7/3/2015 3:19:24 PM • SuperMicro... • Answered on Jul 03, 2015
Supermicro X7DBN failed to boot the bios and prompted data configuration error
This is normally the battery. They last about 5 years. If the battery is weak, replace. Then, go to Advanced BIOS Settings in the BIOS and select PCI Configuration. Set reset configuration data to YES. Reboot.
7/2/2015 9:26:45 PM • SuperMicro... • Answered on Jul 02, 2015
What is topiary motherboard
This is a motherboard that has been decorated by "Case Modders"
7/2/2015 8:44:45 PM • SuperMicro... • Answered on Jul 02, 2015
What is system intilalization 2f
This is a video initialization error. I have forgotten which one. (I think the video RAM) Check the graphic card, or the jumper on the motherboard, depending on the setup of the server. (On board video) If on board video, also check the first DIMM pair.
7/2/2015 7:07:25 PM • SuperMicro... • Answered on Jul 02, 2015
SuperMicro X7DBN-B Dual Lga 771 Xeon/ Intel 5000P/ DDR2/ PCI-E/ V&2GbE Server Motherboard Bulk X7DBN Logo
3 questions posted
Top SuperMicro Computers & Internet Experts
Julie Clark
Julie Clark
ADMIN Eric
ADMIN Eric
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • SuperMicro Computers & Internet
Most Popular Question
system configuration data error
  • Computers & Internet
