20 Most Recent
LG GP08NU20 DVD±RW Burner Questions & Answers
Installer Drive LG GP08NU20 for
Do people read before they write, this thread is about an LG and mac, so saying support is provided in windows is somewhat dumb and unhelpful
Download
Check in Device Manager to insure the usb port(s) are in working order.
Dvd cant read files
Options Available1) Change the resolution and check the DVD.2) Reinstall the driver software.3) Have warranty go back to the seller.4) Check whether the same drive is readable with old cds or protected cds. If the same is the issue5) Check by installing the drive on other laptops (if possible) of the same make.
It wont woek at all
Click start control
panel administrive tools,computer management,device manager scroll down cd-dvd
rom drives you might see a yellow question mark ? right click you will
have options to update driver,roll back driver,or select properties general
troubleshoot, select driver click to reinstall drivers click update
driver or uninstall then reinstall if this does not fix the problem it might be
a registry problem if you cant see your disk drive in windows explorer
Close all open
programs
Click on
Start, Run, and type regedit and press
Enter
Click on the plus signs (+)
next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder
is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the
following names in the right hand column.
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
If any of the above keys shown in step
4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and
check to see if your CD or DVD drives have returned. You may also want to open
Device Manager and verify that the yellow exclamation and error code on the CD
or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug
them back this should activate the found new hardware wizard or
you might have to uninstall
then restart your computer then reinstall your DVD/CD then reinstall the driver
for this device
if your computer came with
a motherboard disk the drivers could be on it
click start control panel
administrive tools computer management device manager scroll down cd dvdrom
drives if you see a yellow question or exclamation mark?! or a red x
right click you will need to update the driver
or
select properties general troubleshoot, select driver
click to reinstall drivers click update driver
hope this helps
In lost the installation software
Problem with the LG GP08NU20 DVD±RW Burner
In lost the installation software to my LG portable super multi drive. Model # GP08NU20. Can I download the installation software?
DEAR SIRS
I HAVE BUY
I had buy a LG Portable Super Multi Drive GP10 and the LG Power Tool software does not have a Video Player. The Help Section of the software show the icon Video Player but it does not appear in my software. Besides, the Windows Media Player does not work for videos. Are there any solution in order to get de Video Player drive or software?
Cannot load my lg gp10
a motherboard disc the drivers could be on it
make sure that the dvd rw is
getting enough power test all leads that are attached to the dvd rw including
electrical extensions and make sure they have a secure connection or just
replace them there might be bad/faulty
or
your drivers may have been
corrupted or you might have a virus run your antivrus program
you might have to
physically unplug the leads for this cd/dvd then plug them back in or
then reinstall your DVD/CD or uninstall the driver then reinstall for this
device
administrive tools,computer management,device manager scroll down cd dvd rom
drives right click you can you can update driver,roll back driver,or
problem it might be a registry problem
Close all open
programs
Click on
Enter
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You
may also want to open Device Manager and verify that the yellow exclamation and
error code on the CD or DVD drive is gone.
hope this helps
I have a super multi
open Itunes in the top left hand corner select file from thdrop down list you will see Library click to open then you should see back up to disk then more options back up entire library to disk
this might be because you have not selected the option to burn an audio cd or your burning software does not support audio burning
there are plenty of free burning software programs on the internet
http://www.majorgeeks.com/BurnAware_Free_d5839.html
BurnAware Free is one of the most popular free CD, DVD, Blu-ray Disc burning software available for Windows. Using this program you can easily create and burn Audio and MP3 CD, Data and DVD-Video disc, ISO and Cue Image, erase or format rewritable disc, copy your CD or DVD to ISO image.
hope this helps
Lost install disk for gpo8
Hi, try any of the similar drivers at....
http://www.opendrivers.com/categorycompany/15/1288/cd-rom-lg-electronics-free-driver-download-page0.html
and see, it might work. let me know if it works.
