20 Most Recent HP Compaq DC7900 Small Form Factor PC Desktop Questions & Answers
Front panel hookup to board on hp 462432-001
Most boards have in real small print, where all the pins go for the front panel. The manufacturer will also have this PDF information for quite a few years on HP.com Oh, the print is just outside the pin block and it's abbreviated - Also the + will indicate the dominate color location. So a red and white cable - The red cable side would be on the +. the pin locations are also color coded in most cases. Hope this is helpful, thank you for visiting FixYa.com If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
2/19/2017 3:43:54 AM • HP Compaq DC7900... • Answered on Feb 19, 2017
My hp Compaq DC7900 has 5 beeps with 5 red light flashing does this 3 times. then the fan kicks on. That's all it does. Anyone know what this is?
This is a sign of a pre-video memory error. If your DC7900 has a video graphics card, that card has probably failed or doesn't have enough power. On at least some of HP's Compaq DC7900, the video card uses a PCIe x16 slot. There are two things to consider when you choose a new video graphics card: 1) it must fit in a slot in your case and 2) your power supply must meet the requirements of the card. The small tower format of the HP Compaq DC7900 came with a 240W power supply. Most modern video graphics cards often need more power. You may need to upgrade the power supply. I hope this helps. Cindy Wells
8/13/2014 2:04:54 AM • HP Compaq DC7900... • Answered on Aug 13, 2014
0answers
Presario cq57 wifi
How can we help? What's your question with wifi?Thanks N.I.T.
6/26/2013 3:26:17 PM • HP Compaq DC7900... • Answered on Jun 26, 2013
Dc7900 sff Power Button?
You can try ebay.
1/24/2013 12:01:14 AM • HP Compaq DC7900... • Answered on Jan 24, 2013
After installing winxp3 on my hp dc7900 small form factor, im having problems with the vga and no sound
Reinstall win xp drivers.http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=3784892&taskId=135
12/9/2012 3:06:23 AM • HP Compaq DC7900... • Answered on Dec 09, 2012
LED activity light not blinking
Check the front panel connector wires for damage. Take the front bezel off and see if the hd led is damaged in any way.
8/21/2012 4:37:18 AM • HP Compaq DC7900... • Answered on Aug 21, 2012
Unmountable boot volume
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
12/1/2011 10:09:12 AM • HP Compaq DC7900... • Answered on Dec 01, 2011
I'm having a problem with HP DC7900 SFF. The Video
The amount of allocated shared video memory is configured in the BIOS configuration - video memory.
6/20/2011 8:26:38 AM • HP Compaq DC7900... • Answered on Jun 20, 2011
0answers
Dc7900 video problems
  • Then DOWNLOAD install video driver.(Graphic Driver)
When you restart your pc the problem will be solved!.
1/4/2014 4:42:14 PM • HP dc Computers... • Answered on Jan 04, 2014
Mico code update error how ifix that
do you mean microcode for BIOS.clear cmos.
4/5/2013 4:55:55 AM • HP dc Computers... • Answered on Apr 05, 2013
Do you need a cpu heatsink fan on a compaq dc5700 desktop pc
Didn't it come with one?
3/20/2013 12:20:09 PM • HP dc Computers... • Answered on Mar 20, 2013
Xw6400workstation hp changed motherboard still4bleeps pc wont start
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Make sure that your RAM modules and Cmos battery are securely seated on some motherboards Cmos batteries are soldered in. Open computer and reseat memory Sometimes when the computer is moved or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Disconnect all expansion cards If the above recommendations still have not resolved the irregular POST, disconnect the riser board(if applicable) and each of theexpansion cards. If this resolves the issue or allows the computer to POST connect one card at a time until you determine what card is causing the issue. Disconnect all drives If you were unable to determine by the beep code what is failing or do not have a beep code disconnect theIDE, SATA, SCSI, or other data cables from theCD-ROM, Hard Drive, and floppy drive from theMotherboard. If this resolves your irregular POST or generates error messages re-connect each device until you determine what device or cable is causing the issue. In some situations it can also be a loose cable connection that causes the issue. Remove the RAM If you continue to to receive the same problem with all the above hardware removed, disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. ' Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue. Re-insert the memory into the same slot. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick. Try one stick of memory in each slot. If you're able to get the computer to boot with one or more of the sticks of memory it's likely you're dealing with some bad memory. Try to identify what stick of memory is bad and replace it. If you're able to get memory to work in one slot but not another slot. You're motherboard is defective you can either workaround the issue by running the memory in a different slot or replace the motherboard. Power cycle the computer In some situations a computer may have power related issues often caused by either the power supply or the motherboard. To help determine if this is the cause of your issue try turning the computer on, off, and back on as fast as possible, making sure the computer power light goes on and off each time. In some situations you may be able to temporarily get the computer to boot. This should only be used as a temporary workaround if you're able to get this to work. Often this is good for users who may have not done a backup and need to get the computer up one more time to copy files before starting to replace hardware. Disconnect and reconnect the CPU (central processing unit) For users who are more comfortable working with the inside of their computer or who have built their computer one last recommendation before assuming hardware is bad is to reseat the CPU by removing it and putting it back into the computer. Bad motherboard, CPU, RAM, or power supply If after doing all of the above recommendations you continue to have the same issue unfortunately it is likely that you have badMotherboard , PSU ( power supply unit ), CPU, or RAM. The next step would be either to replace these components or have the computer serviced. If you plan on doing the repairs yourself or you are a repair shop it is suggested that you replace the Motherboard first, RAM, CPU, and then power supply in that order or try swappable parts from other computers.
2/21/2013 2:29:36 PM • HP dc Computers... • Answered on Feb 21, 2013
HP Compaq DC7900 Small Form Factor  PC Desktop Logo
16 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
dc HP
  • dc HP
Most Popular Question
led activity light not blinking
  • Computers & Internet
