20 Most Recent
Dakota Watch Company Travel Alarm with Magnifier, White Dial, Red Leather Case Questions & Answers
Won't tick
instruction manual for radio watch sm2452 required
How to set the time on a Dakota one button watch
To set the time on a Dakota one button watch, you will need to follow the instructions in the user manual that came with the watch. If you do not have the user manual, you can try the following steps:
- Press and hold the button on the top right side of the watch: Press and hold the button until the time display appears.
- Set the time: Use the button to set the time. The specific sequence for setting the time will depend on the make and model of your watch.
- Exit the time setting mode: Once the time is set, you will need to exit the time setting mode. The specific steps for exiting the time setting mode will depend on the make and model of your watch.
It is important to note that the steps for setting the time on a Dakota one button watch may vary depending on the specific make and model of the watch. If you are unable to set the time using the steps above, it is recommended to refer to the user manual or contact Dakota customer support for assistance.
If you have a "his and hers" set of Dakota watches, the steps for setting the time on both watches should be the same. You can use the steps above to set the time on both watches.
