20 Most Recent
Cartier Authentic Roadster Chronograph W62019X6 Watch for Men Questions & Answers
Is the men's diamond wedding ring real serial #0905524
A genuine Cartier ring will be stamped on the back with Cartier's logo, the jewelry's metal type (Au 750 or 750 for 18k gold or Pt 950 or 950 for platinum), the ring size in mm, and a unique serial number. The stamp should be evenly spaced and, of course, free of any spelling mistakes.
Best to you
How do I change the flint on my Cartier lighter?
I am not familiar with this particular lighter, however, changing flints isn't usually difficult. Could you post a photo of the underside of the lighter? Try turning the lighter upside down. There should be two sections moulded in the bottom of the lighter. One is the refill port you use to fill it with gas, the other will be the adjuster or mount for the flint. The flint holder is usually a Spring loaded tube with the flint mounted at the top end. Carefully unwind the screw or twist cap being careful the spring doesn't suddenly release. This should slide out letting the remains of the old flint fall out. You may need to GENTLY tap the lighter to knock out any dust left by the old flint. Insert the new flint, insert the retaining pin and screw it in until it is finger tight. Screw too tight and you could crush the new flint or damage the screw thread on the retaining pin.
How do i know a
The best way is to have a watchmaker remove the back of the watch. The counterfeits usually have a cheap movement inside and that can help determine if its real or not.
