20 Most Recent Gestetner DSm745 Black and White Copier Questions & Answers
Sc 542
enter service mode then mode then reset/clear sc if it came back than change the thermistors
11/19/2015 12:54:28 PM • Gestetner DSm745... • Answered on Nov 19, 2015
2answers
Again and again got a error of sc329 .......how to fix
this error code came from the LD unit which means the seconder LD is not synchronized on the machine but try to clean the mirror if it came agin the replace the LD board
10/16/2015 1:12:52 AM • Gestetner DSm745... • Answered on Oct 16, 2015
2answers
What does service code sc350 mean?
SC350:
Problem:
ID sensor pattern test error
Description:
One of the following ID sensor output voltages was detected twice consecutively when checking the ID sensor pattern.
1) Vsp ? 2.5V
2) Vsg ? 2.5V
3) Vsp = 0V
4) Vsg = 0V
Possible Problems:
• ID sensor defective
• ID sensor connector defective
• Poor ID sensor connector connection
• I/O board (IOB) defective
• High voltage supply board defective
• ID sensor dirty
• Defect at ID sensor pattern writing area of the drum
** Generally, I've found this problem to almost always be one of the last two items listed above.
5/27/2015 6:27:38 AM • Gestetner DSm745... • Answered on May 27, 2015
2answers
Witch is better Gestetner DSm745 or richo 1045 or
dsm 745 has more modification than1045 more comfortable less disputes little problem. technicians can see this difference there are more details but i expressed that dsm 745 is recently than 1045 good luck
3/4/2015 8:09:38 PM • Gestetner DSm745... • Answered on Mar 04, 2015
The copy is light, who can i fix it
kindly check if there is enouh developer in the unit .if there is check the glass covering the laser unit and clean it. if there there is no developer then change it and the problem is solved
6/6/2014 1:26:14 PM • Gestetner DSm745... • Answered on Jun 06, 2014
Service mode enter ricoh aficio
press th orange key, say three times. press 107 with the keys. press and old the clear or cancel or stop key for about four seconds. the ma chine will naw take yu to the sp mode.
6/6/2014 12:59:45 PM • Gestetner DSm745... • Answered on Jun 06, 2014
0answers
Too many lines on sheet when printout from
check the upper fuser roller for wear,
11/12/2013 3:31:18 PM • Gestetner DSm745... • Answered on Nov 12, 2013
0answers
What is service code sc350 and how do I fix it?
SC 350: The most common ID sensor dirty: Clean the ID sensor
6/23/2011 2:12:38 AM • Gestetner DSm745... • Answered on Jun 23, 2011
Quando ligo a maquina dsm715
Independente do modelo ser Dsm715 ou Dsm745 esse codigo corresponde a um erro na Unidade de Laser, mais precisamente com o sincronismo.
A primeira coisa a verificar nestes casos é se a Unidade de Laser está suja. Por vezes cai toner para o Laser e provoca estes codigos.
Se tiveres conhecimento tecnico saberás chegar á unidade de Laser. Se não tens esse conhecimento aconcelho a não mexeres (chama alguem que o saiba fazer).
Na minha opinião este deve ser o primeiro passo a dar. Deves fazer uma limpeza na Unidade de Laser.
Se não resultar replica para mim ou volta a colocar a questão no Fixya. Existem otros factores que podem provocar este codigo.
Fica bem!
4/25/2011 11:15:47 PM • Gestetner DSm745... • Answered on Apr 25, 2011
0answers
Sc322-000
Be the first to answer 4/6/2011 11:44:54 AM • Gestetner DSm745... • Posted on Apr 06, 2011Be the first to answer
What is the service mode
there is programs help technitian to determine disputs and find solution for all proplems
3/25/2011 6:56:38 AM • Gestetner DSm745... • Answered on Mar 25, 2011
It can not copy well
Let me understand your problem. You are saying that the text is not black in areas on the print, they appear to be white or washed out. If this is the case the first thing that you may try is to remove the "toner shield glass" and clean it. It is located directly under the toner bottle tray, possibly behind a little metal bracket. It just slides out to the front of the machine. If that does not help, then the machine would likely need to have the developer and drum replaced.
3/12/2011 4:29:51 PM • Gestetner DSm745... • Answered on Mar 12, 2011
Gestetner DSm745 Black and White Copier Logo
34 questions posted
Top Gestetner Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Gestetner Office Equipment & Supplies
Most Popular Question
witch better gestetner dsm745 or richo
  • Office Equipment & Supplies
