20 Most Recent Dell Latitude XT Laptop Computer Tablet PC Questions & Answers
My dell latitude wont boot
Try turning it on with it plugged in.
11/7/2018 2:06:27 PM • Dell Latitude XT... • Answered on Nov 07, 2018
Broken hinge
Not really, those are some pretty heavy duty tension hinges.
11/18/2013 1:38:31 AM • Dell Latitude XT... • Answered on Nov 18, 2013
3answers
My pen for my computer won't work
I think the pen has gone bad on you, since your screen can still detect your hand and the track pad. I would think the pen is faulty. Try another pen cause I think your original is bad, if it was the touch feature that wasn't working I would say its a driver problem but that feature still works with the exception of the pen. Get another pen.
7/19/2013 9:03:38 PM • Dell Latitude XT... • Answered on Jul 19, 2013
Delll latitude xt wont restore
Hi kaliyahsherr,
I see that your Dell will not restore to an earlier restore point.
What version of windows do you have on your Dell?
I believe you already did try to do system restore but it did not work right, does it give you an error unable to restore to the selcted restore point, if that is the error then meaning there is a peroblem with that restoration point that you have selcted have you tried a different restore point?
If you did then most probably the system restore program on your windows is having issue restoring the system to any date that you may have on your system restore. if this is the case then the only option would be reinstalling windows starting from scratch.
There is another way to do System Restore on your computer but this is only known to work with Windows XP, I haven't tried with Vista nor Win7 yet.
we do a System Restore in the Command Prompt, see steps below.
> From shut down turn your Computer back on then keep on tapping F8 to select and boot into Safemode in Command Prompt.
> Once in the Command Prompt on the blinking cursor you should type in \windows\system32\restore\rstrui.exe after typing this in it should look like this C:\windows\system32\restore\rstrui.exe, then press Enter.
> After pressing Enter this should show you a list of dates for the restore points highlight a data and time when you want to do the system restore and see if it will work outside windows.
> If this does not work then there is something wrong with Windows and needs to be reinstalled for the fix on your concern.
I hope that this information can be helpful regarding your concern.
Have a nice day,
mvincentc
5/24/2011 7:54:43 AM • Dell Latitude XT... • Answered on May 24, 2011
When coming out of standby mode the keyboard gets
Do you mean that you see the press Ctl-Alt-Delete to continue ?
This is the Windows lock screen.
You can disable this by going in Control Pannel -> Power Options -> And select " Dont require password on wake up"
2/28/2011 6:16:05 PM • Dell Latitude XT... • Answered on Feb 28, 2011
What is required for internal Cellular SIM
What you need is a laptop/netbook with a 3g modem.some people reckon this is the best way to connect out and about on the train etc.
Only certain models of netbook have them and the net searches just bring back confusing information and duplicate specification information that is wrong or refering to other products--The problem is this seems to be the future technology but the manufacturers are trying to get rid of the old stock that do not have this function,,so they try and confuse the customer into buying the wrong model.
You will need to remove the battery compartment to see if there is a slot for a sim card usually at one end of the compartment.
The HP mini series have one but they dont plug its specification in the advertising bumf,probably because they want to get rid of old stock.Samsung do one --NC10.And asus do a new series with this function but beware,go armed with the correct model you want and make sure the shop assistant is selling you the correct model also-the spec numbers are very similar on some brands
9/12/2010 3:21:05 PM • Dell Latitude XT... • Answered on Sep 12, 2010
Want to use toshiba pen on Dell XT tablet, but not
No, sorry.
The DELL Latitude XT uses digitizer technology from N-trig and the Toshiba uses Wacom technology.
Completely different and non-interchangeable.
12/21/2009 11:02:37 PM • Dell Latitude XT... • Answered on Dec 21, 2009
I own a Dell Latitude XP2 Tablet Notebook. It has
Did it start to get noticeably hot in certain parts of the enclosure? If so, you may have an overheting problem due to a failing fan, or something (dust, lint...) clogging the air circulation ducts and the radiator.
Try listening to the fan and finding out if it's running at full speed when the computer is getting hot, and if air is freely coming out of the air outlet (on the back or side of the unit). You can try compressed air blown in the oposite direction to the air flow (blow into the outlet grill) to blow away dust and particles that may obstruct the radiator and duct.
11/28/2009 2:33:39 PM • Dell Latitude XT... • Answered on Nov 28, 2009
My dell tablet has : Unfortunately, System UI has stopped. Haw can I fix this?
if your have faced this issue while using your computer. Then you need to follow these steps to fix UI Failed to Load on windows https://www.mygeekshelp.com/avast-ui-failed-to-load-after-windows-10-update
6/21/2019 5:20:58 PM • Dell Tablets &... • Answered on Jun 21, 2019
3answers
My dell tablet has a windows 10 and will not rotate the screen
Reads like the display drivers need to be updated to some compatible with Windows 10..
12/4/2018 4:14:32 AM • Dell Tablets &... • Answered on Dec 04, 2018
2answers
How to get pst my screen lock dell v8 tablet forgot password
Once into the Dell Venue 8 or11's UEFI BIOS, disable Secure boot ... password you got lost and would like to perform password reset on. Click on the Reset Password. -> Restart the tablet and return to the sign-in screen where you won't have to type in a password. https://www.skypesupports.com/
5/31/2018 1:10:32 AM • Dell Tablets &... • Answered on May 31, 2018
I use a DELL LAPTOP ONLY and not IPADS. For the past week I have not been able to send lives to my friends using candy crush saga or soda. Can you fix this problem on my computer?
I'm sure I can! Why don't you bring your computer over this afternoon, and I will see what I can do for you ... for free, of course!
5/15/2017 6:15:37 PM • Dell Tablets &... • Answered on May 15, 2017
Dell venue 3730 lockscreen bypass
Hardware Key Reset If your device is not working because it is frozen then you wouldn't be able to reset it with the software. So the next option would be the hardware method. 1. Press and hold down the Power button + Volume down button + Camera button all at the same time until the device vibrates, now let go of the Power buttonwhile continuing to hold down the Volume down button and theCamera button. 2. Shortly you should see the message displaying "Are you sure you want to format?", you can now release the Volume down button + Camera button. 3. In the format screen you have the option to either Format or Cancel. Tap on Windows key Format if you are confident to go ahead. 4. Press on the Windows key again to confirm your choice. Your device should now begin to format the device and shortly should startup with the Start-up Wizard. Ensure you device have the battery power while doing this
12/27/2016 12:14:18 PM • Dell Tablets &... • Answered on Dec 27, 2016
How do I disable the onscreen keyboard on a dell tablet?
Jeanne Scott, You can click the link below to choose your tablet from the list. Once you choose your device you can download the online manual. The manual provides information on performing task within your tablet. Dell Support http://dell.to/1C6plZK Thank You, Dell-Jesse L Dell Social Media and Communities
3/31/2016 1:28:26 PM • Dell Tablets &... • Answered on Mar 31, 2016
How do I hard factory reset dell venue8-3840 tablet
Your best bet is to google your specific device, but some have a small hole on the side and you can use a paper clip. Or power off, then power back on holding the power and volume down button down until a menu shows up on screen. You may have two or three options such as hard, soft, or recover reset.
11/30/2015 5:48:38 AM • Dell Tablets &... • Answered on Nov 30, 2015
Dell Latitude XT Laptop Computer   Tablet PC Logo
19 questions posted
Top Dell Tablets & eReaders Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Josh Lake
Are you a Dell Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
LATITUDE Dell
  • LATITUDE Dell
Most Popular Question
want use toshiba pen dell xt tablet but
  • Tablets & eReaders
